Poll
how do i bypass my ignition?
0 (0%)
0 (0%)
Total Members Voted: 0
Author Topic: kymco 50 no spark  (Read 17298 times)
tadman6
kymco 50 no spark
« on: November 19, 2012, 08:55:43 PM »
 ordered new ignition but still want to ride my scooter can't seem to figure it out? Any help would be apperciated.
tortoise
Re: kymco 50 no spark
« Reply #1 on: November 20, 2012, 02:50:28 AM »
how do i bypass my ignition . . still want to ride my scooter can't seem to figure it out?
Pudsey variation (not scooter related)
« Last Edit: November 20, 2012, 03:11:13 AM by tortoise »
Peters
  • In Glock I Trust
« Reply #2 on: November 20, 2012, 03:49:51 AM »
I'm no ignition expert but, you have the coil, stator, and CDI. Any of those could be bad. Start by checking for simple things like damaged wiring or bad connections.
What model is your scoot?
*2001 ZX-50 beater
LoveMyKymco
« Reply #3 on: November 20, 2012, 02:15:18 PM »
This might help
LoveMyKymco
« Reply #4 on: November 20, 2012, 02:15:52 PM »
+2
LoveMyKymco
« Reply #5 on: November 20, 2012, 02:17:07 PM »
+3
LoveMyKymco
« Reply #6 on: November 20, 2012, 02:19:00 PM »
To bypass your switch I need a diagram for the scoot you have so I can trace it back, but honestly to make your bike run with out an ignition switch on most bikes all you have to do is cut the kill switch to the cdi. Also the wiring for the ignition system is the same from a 50cc, 80,90,110,125, and a 150, just different colors and or plug shape differences if any change.
« Last Edit: November 20, 2012, 02:21:14 PM by LoveMyKymco »
naughty lee
  • 64 mph and pushing
« Reply #7 on: December 27, 2012, 02:24:19 PM »
If you are sure your cdi is ok, I'd be looking at coil connectors, (google coil primary and secondary winding resistances) once you've done this, if you haven't got a spark, the fault can only be on your plug or ht lead
tpryde1
« Reply #8 on: January 02, 2013, 12:48:43 AM »
If all other advice given fails to yield a spark, you need to check your stator pickup coil/ Hall Sensor. This is a small coil on the outside of your stator. basically it is a permanent magnet rod wrapped with copper wire. As the raised plate on the stator passes this coil just prior to TDC a small amount of voltage is produced (.5 to 1 volt is acceptable) This sends a signal to the CDI to release the stored voltage to the coil. I have had 2 of these go bad on different scooters in the past 5 years.
To test simply disconnect the single wire that comes from the Pickup coil. Usually there is a single connector if you follow this lead up under the bike (likely need to remove the seat). Take your ohmmeter and set it to AC, put one ohmmeter wire into the line going to the Pickup coil and ground the other ohmmeter wire to the engine block or a ground wire nearby. Crank the engine over and read the pulse voltage. If you don't have close to .5 volts there's your problem.
Mu last failure of the pickup was just 6 months ago on my Super 8-150. When Cranking I got .19 volts and the plug would not fire. I bought a cheapo GY6 coil assembly off ebay that included this sensor it was about $13. The coil was not designed for Kymco's but most of the single wire Sensor Coils are the same. So just leave yourself enough wire and cut the new sensor off the new coil and solder and shrink wrap it to the wire on the bike.
Worth a shot anyhow and good luck!
naughty lee
« Reply #9 on: January 02, 2013, 05:03:06 PM »
A wire fed directly from the positive connection on the battery to the coil may get your bike going. I say "may" as it was a trick showed to me that would start a military land rover if the keys were lost
MotoRandy123
  • Lets Ride!
« Reply #10 on: January 02, 2013, 06:44:48 PM »
Guys the original poster posted then disappeared. I guess he figured out how to
get it going...
