Author Topic: Heat cycle?  (Read 1693 times)
Raindrop
Heat cycle?
« on: December 02, 2012, 06:54:11 PM »
How long should i let it run. ?
What temp before let cool down?
And does anyone use stock pet cock or am i better off taking off?
2004 kymco super fever
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
Raindrop
Re: Heat cycle?
« Reply #1 on: December 09, 2012, 01:57:13 PM »
Wow great info.  lol
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
LoveMyKymco
Re: Heat cycle?
« Reply #2 on: December 10, 2012, 12:32:30 AM »
If you have a temp gauge let it hit at least 250F and shut it off and let it cool down past 100 F around 4-10 times. I would ride it around very slowly just hitting the throttle every once in a while doing a lot of up and down on the rpms not staying the same rpm for long or high rpms. Thats just for heat cycles, then comes break in.
Raindrop
Re: Heat cycle?
« Reply #3 on: December 10, 2012, 01:06:49 AM »
Ok waiting for jets came stock with 107 or 108 ... but cold weather kicking in here ..
What's the break in part .. and is Stock pipe bad for it?
« Last Edit: December 10, 2012, 06:58:30 PM by Raindrop »
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
