In looking around the interWebs I found this chart;
It shows the length of the intake tract to tune for different RPM's. The tuned RPM can have
10% more flow so it's an easy way to give us a little boost. The stock length appears to be
around 22". It's a little tough to measure as it's the length from the intake valve to the bell
mouth in the airbox;
So it looks like we are tuned to 6500 RPM's which is where the torque peak is. If we wanted to
experiment with setting it higher we would need to shorten the intake pipe and put the new bell
mouth on the now shorter tube. This would necessitate an extension on the airbox to contain
the now shorter intake on the inside side of the air filter.
One problem is the bell mouth is glued to the airbox. The second is how to cover the new shorter
end into the airfilter box? Anyone up for some tuning?
