Author Topic: Where to buy super9 AC reeds...  (Read 6286 times)
Superstu
« on: December 16, 2012, 04:51:10 AM »
I have been looking everywhere for reeds for my super 9. I can't seem to find them bc I have a chip in one of mine. Help would be greatly appreciated.
Thanks
stu
Super9r
Re: Where to buy super9 AC reeds...
« Reply #1 on: December 16, 2012, 08:31:56 AM »
If you want stock Stadium Yamaha has the complete reed assembly.
14100   14100-KEB7-900    VALVE COMP REED   $33.48
Or powersportswarehouse.com is cheaper
14100   14100-KEB7-900    VALVE COMP REED   $28.18
Stadium Yamaha is a known good provider of spare OEM parts.
« Last Edit: December 16, 2012, 08:34:35 AM by Super9r »
2003 Super 9 LC Red and Black Baby!
Superstu
« Reply #2 on: December 16, 2012, 07:28:36 PM »
Thanks for the quick response. Bit I'm looking for cf reeds.
Super9r
« Reply #4 on: December 18, 2012, 01:12:29 AM »
...oem reeds are hhharrrd to beat onna oem scoot....
Superstu
« Reply #5 on: December 18, 2012, 01:27:39 AM »
I see that they are for the LC model. I have the AC model are the reeds the say for both models?
Also I have a bbk so I think stock reeds probably would flutter.
Thanks
stu
« Reply #6 on: December 18, 2012, 01:33:34 AM »
...you may be right...didnt know you had bbk...
..i'm pretty sure th reeds are same for both...
Superstu
« Reply #7 on: December 18, 2012, 01:37:39 AM »
Ok thanks
« Reply #8 on: December 18, 2012, 01:48:32 AM »
..super9, ppl, cobra...believe they all oem same...
Super9r
« Reply #9 on: December 18, 2012, 08:23:56 AM »
Malossi reeds are the same for all the ones wordslinger meantioned.
Superstu
« Reply #10 on: December 18, 2012, 10:38:19 PM »
Thanks so much been trying to find that out for ever. What size roller or slider do you use on your S9?
« Reply #11 on: December 19, 2012, 01:02:18 AM »
..i'm running 6.5 gram Dr Pulley sliders...
..keeps nina in th power, and tops out @ 65 indicated....
Superstu
« Reply #12 on: December 19, 2012, 02:48:45 AM »
Wow 65 do you have upgraded gears? I only get to 50 and it's revin so high I let off.
« Reply #13 on: December 19, 2012, 02:52:25 AM »
..no, nina is oem final drive...
..its all good fuel mix and cvt..
..do you have unrestricted driven pulleys?...
..the ac will never perform like th lc...
« Last Edit: December 19, 2012, 02:55:44 AM by wordslinger »
Superstu
« Reply #14 on: December 19, 2012, 05:28:14 PM »
Yes it has the restricted boss out. I with I could have got the LC.
