Author Topic: My Kymco ZX50  (Read 5810 times)
Raindrop
My Kymco ZX50
« on: December 18, 2012, 08:04:36 PM »
Here are some pics ...
So far 48mm BBK .. 24mm oko ... carbon reeds .. Polini Varitor with stock weights .. stock clutch .. V-8 Exhaust - In Mail lol
What else should i by to make this thing go 0 -50 quick !
« Last Edit: December 18, 2012, 11:10:02 PM by Raindrop »
2004 kymco super fever
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
LoveMyKymco
Re: My Kymco ZX50
« Reply #1 on: December 24, 2012, 07:42:21 PM »
Do you run it with out part of the fan cover/shroud off? I would not do that if so, it may seize from heat.
Have you done the green wire mod? They sell a blue cdi and orange coil that works really well for the ZXs, some people say it doesnt help but it does change the timing a little more than stock and the coil is higher voltage.
I dont remember if youre running pre mix or pump in, but if your running the pump in just add about an Oz of oil per gallon of gas in the tank and it will help raise the amount of oil ratio enough to be ok for it. You might have to run a larger jet when you do because it will help lean out the air fuel ratio by adding more oil into the equation and no extra gas actually less gas through the same orifice.
You will top out around 60- 65 with stock gears on it and that will be pushing it. Theres not a lot of options for after market gears for our scooters as you will find out. You can not use the dio secondary gears sold by the vendors on ebay, you have polini or malossi primary gear sets to choose from and thats it. I knew someone who had some secondary gear sets cut for him but not sure what the specs were. Either way its not cheap to change the gears, follow my link to see mine.
Raindrop
Re: My Kymco ZX50
« Reply #2 on: December 24, 2012, 09:29:49 PM »
The fan cover is on.  and i have a oil  plug in it so i pre mix.
Whats clutch springs should i get?
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
LoveMyKymco
Re: My Kymco ZX50
« Reply #3 on: December 25, 2012, 04:17:29 PM »
You really dont need to change your clutch triple springs, you need to change the contra spring that goes under the clutch. I would get a yellow malossi spring.
http://www.hondaspree.net/phpBB3/viewtopic.php?f=2&t=19538&hilit=malossi+parts
twhit
Re: My Kymco ZX50
« Reply #4 on: March 22, 2013, 09:01:16 PM »
Raindrop what main jet did you use. I got the same stuff that you got.  Will be putting together soon just got the exhaust carb kit and reed valve, just wonder what you did?
  thanks twhit
 Annarbor mi
Raindrop
Re: My Kymco ZX50
« Reply #5 on: May 13, 2013, 05:04:44 AM »
125
48mm Bbk
Polini variator
High flow intake
4-slot reeds
24mm oko
