Did you miss your
activation email
Technical | How To
bet and win cold start issue
Topic: bet and win cold start issue (Read 1227 times)
partyhut
imstilriden
Jr. Member
December 19, 2012, 12:38:47 AM »
starts well in mild weather, when cold must crank for uncomfortable amount of time to start. after first run, starts well rest of the day. what cold start componants are incorperated on this model? what to suspect, how to test. any help welcome thanks !
scootenalong in
Soddy Daisy, Tennessee
undead primate
Re: bet and win cold start issue
December 19, 2012, 01:44:51 AM »
..welcome to the forum, partyhut!!
..awesome nickname, btw...
..give us a little more info on your scoot, if you will..
..like year, kilometers (miles), any mods...
...may need nothing more than a tweak to the idle mix screw on your carb...
December 19, 2012, 02:29:08 AM »
I just keep a 75 w light bulb turned on under the seat. just need to turn it on a hour or so befor rideing.
you well need to take the bottom of the seat out so the heat gets to the carb. if your air lines and gas lines stay a little worm you should have no prolem starting.dont go no hot then a 75 w 100 well do damage. its to hot.
undead primate
Reply #3 on:
December 19, 2012, 02:41:14 AM »
..have the valves ever been adjusted?
undead primate
Reply #4 on:
December 19, 2012, 03:16:49 AM »
..well, a 4t scoot with 8000+ miles may very well be due for a valve adjustment...
..below is a link to the service manual for you scoot...
..check it out..look at what valve adjustment is all about...
..every scooter owner needs their scoot's service manual..
http://www.timtaylor.net/
ophelia
Sr. Member
Reply #5 on:
December 19, 2012, 06:33:42 PM »
Definitely check exhaust valve adjustment.
Batteries work less well in the cold too. I've replaced my battery once already, and the new one cranked a bit faster than the one it replaced. Keep it topped up regularly if the scooter gets put into storage or not run for a few weeks.
2011 Kymco Downtown 300i
undead primate
Reply #6 on:
December 20, 2012, 01:23:56 AM »
...hey...there's a post missing...lol...
de-dee
Sr. Member
Reply #7 on:
December 20, 2012, 04:38:25 AM »
???Dose it make any differance how cold it is when you adjust the valves, ???around freezing temp. in my garage,. on a nice day, or should I wait for spring,
Damn long winter in canada, joe
undead primate
Reply #8 on:
December 20, 2012, 11:53:14 AM »
..i've always adjusted mine at whatever the ambient temps are...
Back
