Author Topic: Starter keeps running - Solved  (Read 1622 times)
wrenchmonkey
« on: December 24, 2012, 11:13:46 PM »
I've had the same problem that was reported in
http://www.kymcoforum.com/index.php?topic=2485.0
http://www.kymcoforum.com/index.php?topic=4115.0
where the starter keeps running even when you turn the scooter off and pull the key out. The dealer told me that it is the starter relay and gave me a new one. A few days later, same problem. Within one day, I had to take the seat off twice and hit the starter relay with a wrench, and the starter immediately stopped running. To me, that's proof that it is the starter relay that gets stuck.
I decided to try a different relay, based on mudshark's post, and got a 40 A Duralast relay from Autozone and a matching wiring harness from Pep Boys. Since then, no more problems!
bandit
Re: Starter keeps running - Solved
« Reply #1 on: January 14, 2013, 04:09:34 AM »
Thanks for the info and the picture. I had mine replaced twice and my 2 yr. warranty runs out next month.I am going to try this when it sticks open again. Of course it will go bad after the warranty expires! ::)
MotoRandy123
  • Lets Ride!
« Reply #2 on: January 14, 2013, 01:07:23 PM »
  So are we thinking the stock relay can't handle the current? I have an old BMW that likes to
weld the starter relay but only when the battery voltage is low...
 My Honda Fit car had a poor connection from the frame to engine (from brand new!) so I
added a 4 gauge jumper, it used to turn over slowly now it's fine!
« Last Edit: January 14, 2013, 01:10:00 PM by MotoRandy123 »
« Reply #3 on: January 14, 2013, 11:25:21 PM »
..sounds like it...somebody check part # cross-reference with the ppl 150 relay...
..bet they the same...
