Did you miss your
activation email
Technical | How To
Question about TDC and timing
Topic: Question about TDC and timing (Read 1625 times)
Trancebear
Sucker For Discontinued Scooters
Full Member
Retired Micro$oft Drone
December 31, 2012, 04:34:55 AM »
The manual seems to not be that clear on where my flywheel needs to be. When installing my new camshaft along with my 300cc kit I used the mark on the flywheel right next to the T imprinted on the flywheel. Is this correct or should I align it with the T itself? See picture for reference.
My Name Is Chris Y'all
2014 BMW 650GT
2014 Kymco MyRoad 700 Modded
2006 Kymco B&W 250
Threw Away All The Chinese Scoots
MotoRandy123
Lets Ride!
Re: Question about TDC and timing
December 31, 2012, 02:07:25 PM »
I found this in a write up on TimTaylor on adjusting the People 250 S valves (it should be in all the manuals!);
http://www.timtaylor.net/Scooter/Manuals.htm
Last Edit: December 31, 2012, 02:09:23 PM by MotoRandy123
Trancebear
Full Member
Re: Re: Question about TDC and timing
December 31, 2012, 03:20:51 PM »
You are awesome! Thanks a million. Now I have to figure out why the darn thing won't start.
2014 BMW 650GT
2006 Kymco B&W 250
MotoRandy123
Lets Ride!
Reply #3 on:
December 31, 2012, 04:14:29 PM »
Well timing is first then check the valve adjustment. Also look for something you forgot to
re install (plug?). Good luck!
Back
