Author Topic: Parts Lists  (Read 1984 times)
Mad scientist
Parts Lists
« on: January 07, 2013, 06:43:53 PM »
With the tax return season coming up I'd like to purchase some parts. Price cap is 300. would like some performance as far as speed and acceleration. Whats my best bet?
MotoRandy123
  • Lets Ride!
Re: Parts Lists
« Reply #1 on: January 07, 2013, 07:18:22 PM »
Well you can't go wrong with DR Pulley sliders. They're only $35 and make a big difference.
The general idea is to get them 1 gm less in weight from the stock rollers...
Mad scientist
Re: Parts Lists
« Reply #2 on: January 07, 2013, 07:26:59 PM »
just sliders? what about a carb or clutch setup or springs? also want to lower it a bit kinda sits high up?
MotoRandy123
  • Lets Ride!
Re: Parts Lists
« Reply #3 on: January 07, 2013, 07:40:48 PM »
 Well I don't have that model so can't make specific recommendations. It is a 4 stroke so
beyond the sliders you would need to get a BBK and carb and exhaust to see a lot of gain...
 To lower it you could cut the springs in front and add something like this in the back;
MotoRandy123
  • Lets Ride!
Re: Parts Lists
« Reply #4 on: January 07, 2013, 07:46:43 PM »
Is it fully derestricted?
Some of the newer models need a different boss to derestrict them too. How fast does it go now?
« Last Edit: January 07, 2013, 10:26:21 PM by MotoRandy123 »
Mad scientist
Re: Parts Lists
« Reply #5 on: January 07, 2013, 08:03:57 PM »
im looking for an adjustable coilover for the back and the front forks i could just adjust from the crown that holds shock itself. but was gonna do the cut cdi and the variator boss and possibly the carb jet and air filter setup. also doing drop handle bars, and relocating the marker lights and speedo
streido
Re: Parts Lists
« Reply #6 on: January 07, 2013, 09:44:55 PM »
Stiffer torque spring, lighter rollers or sliders, race variator such as Malossi Multivar and correct jetting are the most cost effective way to tune it up. A well tubed cvt will give you a good base to work from.
I run 1500rpm torque with 5.5g rollers usually, with a shortened boss.
Chaos is my co-pilot.
streido
Re: Parts Lists
« Reply #7 on: January 07, 2013, 09:48:19 PM »
You prob know most of this but it may help for something.......
http://www.kymcoforum.com/index.php?topic=6198.0
tortoise
Re: Parts Lists
« Reply #8 on: January 07, 2013, 11:53:49 PM »
Why did you NOT initially select a scooter that was actually suitable for your performance expectations?
Re: Parts Lists
« Reply #9 on: January 08, 2013, 02:54:26 AM »
..year, kms??
...for 300 US dollars, we can get you doing 50+ downhill if you're riding a 09 or less a50...
...my addy is wordslinger0@gmail.com ...
..send me a US Postal Service money order.....
..no, dont do that....
                   :o
« Last Edit: January 12, 2013, 12:56:53 AM by wordslinger »
Mad scientist
Re: Parts Lists
« Reply #10 on: January 08, 2013, 04:17:46 AM »
That link helps a lot thank you guys! As far as places to order from, moped hospital?
Re: Parts Lists
« Reply #11 on: January 12, 2013, 12:56:18 AM »
...partsforscooters.com...
..scooterpartsplace.com
..stadiumyamaha.com...
..these all have good reputations...
