Author Topic: roller weights....?  (Read 5128 times)
eyco
roller weights....?
« on: July 06, 2009, 07:49:15 PM »
hi, i want to replace the oem weights for Dr.pully sliding weights. any suggestion on the weight of the weights?
the oem is 21g so i was thinking on the 24g. or should i stay with the 21g by dr.pully? i more into high speed but keep a reasonable takeoff in the city.
dejzebmoorbn
Re: roller weights....?
« Reply #1 on: May 11, 2012, 11:46:15 AM »
http://scootdawg.proboards.com/index.cgi?board=talk&action=print&thread=13775
Good info, though not B&W specific. Consensus is sliders are better than rollers. I'm staying close to 20g (19-21 probably).
NigelB
« Reply #2 on: May 25, 2012, 12:43:03 AM »
I have been using 24g weight rollers for 30 000km (19000 miles). They work for me and dropped my topend revs a whole lot, but then again I am a skinny guy at 160 lb. My next weights will be 26g or 28g.
« Reply #3 on: May 25, 2012, 04:14:33 AM »
Go heavier than your current weights to keep the same cruise rpm. Staying the same will increase rpm's
Trancebear
  • Sucker For Discontinued Scooters
  • Retired Micro$oft Drone
« Reply #4 on: June 03, 2012, 03:21:26 AM »
My 2006 had 20g stock and my RPM's where not hitting the HP peak I wanted so I dropped then down to 16g. I weigh 380lbs so I have to do this on every scooter I own. I went with Dr. Pulley Sliders as with all my other scooters.
My Name Is Chris Y'all
2014 BMW 650GT
2014 Kymco MyRoad 700 Modded
2006 Kymco B&W 250
Threw Away All The Chinese Scoots
