Did you miss your
activation email
Technical | How To
04 b&w 250 throttle cable problem
Topic: 04 b&w 250 throttle cable problem (Read 960 times)
partyhut
imstilriden
Jr. Member
January 12, 2013, 05:19:55 PM »
The throttle cable has a lot of slack in it on the return side at the card. More than the adjustment can correct. Does the cable stretch over time?
The throttle works smoothly from the hand grip. Is there some adjustment I have missed? Not enough take up at the grip end either.
Worries me to ride it in this condition. Could I have a frayed cable that is about to break or what? In need of advise and instruction ole PH
scootenalong in
Soddy Daisy, Tennessee
undead primate
Re: 04 b&w 250 throttle cable problem
January 12, 2013, 10:40:30 PM »
..yes, cable will stretch, especially if pulled hard, WOT a lot...
..could be frayed as well...thorough inspection at both ends is in order, at least...
..there should be adjustment at both ends of the cable, tho i'm not familiar with your scoot...
partyhut
imstilriden
Jr. Member
January 13, 2013, 03:01:25 AM »
followed advice - got to both ends of both cables. Ends ok pulled on each. the return cable is apart in the cable sleeve
will have to replace return side cable..
scootenalong in
MotoRandy123
Lets Ride!
Reply #3 on:
January 13, 2013, 11:59:01 AM »
I like to take those out, makes it easier to turn. The spring does the returning and I've never had one break!
partyhut
imstilriden
Jr. Member
Reply #4 on:
January 13, 2013, 08:25:08 PM »
that sounds reasonable, of all the bikes i've had, this is the first time I remember having a return cable.
scootenalong in
Back
