Author Topic: B&W 250 dash buttons  (Read 6314 times)
partyhut
  • imstilriden
« on: January 15, 2013, 01:33:07 AM »
I've seen several posts about the buttons on the B&W 250 dash, none of which were responded to with clear cut answers.
I did find out from one how to toggle the ambient temp. between F. and C.  Would like the clock on standard 12 hour instead of 24.
Have no clue as to how to sequence the three buttons nor what each changes.  The sensor for the ambient temp. is mounted under
the bonnet in front just over the radiator. not the best choice, when scoot sits and idles for any amount of time the heat rising from
the radiator jumps the outdoor temp. reading up quite a bit. once aware of this not much of a problem.  Had me going a time or two on the front end.   Anyway, anyone with any info on these dash buttons please share..  I am about to the point of overcoating them
with a coat of good, tough epoxy to keep me from fiddle farting with them every time I ride    ???
scootenalong in
Soddy Daisy, Tennessee
KymcoBW250Fan
Re: B&W 250 dash buttons
« Reply #1 on: January 16, 2013, 01:27:51 AM »
Right button toggles through the hours and minutes. Left button toggles through month, day and seconds, center button is used to add units. So, press/hold the right button, and the hours will blink, then you can use the center button to increase hours. Press the right button again to go to minutes, then use center button to increase minutes. Left button, date will blink, increase months with center button, press left button again, increase days with center button, press button again, and you can reset seconds to 0. Press left button once more, and you are all set. Press/hold center button to switch from C to F. I don't think you can change from 24h to 12h, at least I haven't found a way.
2002 Bet&Win 250, 26,000 miles
2003 Bet&Win 250, 47,000 miles
2006 Vitality 50, kitted to 70, 26,000 miles
Aurora, Colorado
partyhut
  • imstilriden
« Reply #2 on: January 16, 2013, 02:26:12 AM »
thanks, that was a big help  ride safe, be well, live long
scootenalong in
MotoRandy123
  • Lets Ride!
« Reply #3 on: January 16, 2013, 12:03:09 PM »
I know on my Yager I have the book and still change something I didn't intend while messing with it.
I still haven't figured out how to use the trip meter, there's no indication that your looking at it and
my mileage isn't enough to tell the difference...
KymcoBW250Fan
« Reply #4 on: January 18, 2013, 06:50:47 PM »
Can't help you there, B&W doesn't have a trip meter. I usually just measure my trips by the amount of pleasure I get from them. They tend to hover around a perfect 10.
Bert
Aurora, Colorado
MotoRandy123
  • Lets Ride!
« Reply #5 on: January 18, 2013, 08:32:41 PM »
Ya I don't usually worry about it but I was trying to see my total mileage for the year.
I only just got it in October so didn't get much this year!
