Author Topic: damn idle  (Read 2849 times)
superscoot
  • if you see blue light's ""RUN""
damn idle
« on: January 28, 2013, 06:45:44 PM »
so i installed my new 70cc kit and having trouble with the idle...when i go for a ride then come to a stop it hangs at 3000rpm then drops down after a min or so...so im guessing would a larger pilot jet solve the issue? ive messed with the a/f its backed out at about 1/4 to 1 turn
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 5.7 gram rollers
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
naraku 1500 contra spring
naraku 2000 clutch springs
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
MotoRandy123
  • Lets Ride!
Re: damn idle
« Reply #1 on: January 28, 2013, 08:17:32 PM »
That can be caused by an air leak into the intake I think...
superscoot
Re: damn idle
« Reply #2 on: January 28, 2013, 10:07:43 PM »
good thinking...ill have a look tomorrow, i doubt it is a leak tho as it sits and idles nice when started...its when i  take it out for a ride thats when i get the idle problems, i dunno worth a look rule out some issues cheers :)
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
Peters
  • In Glock I Trust
Re: damn idle
« Reply #3 on: January 29, 2013, 05:58:16 AM »
On 2 strokes the exhaust side can pull in air as well. Soapy water in a squirt bottle can find any leaks. I'd check and make sure nothing is hanging up in the carb first though.
You still running the stock carb?
*2001 ZX-50 beater
superscoot
Re: damn idle
« Reply #4 on: January 29, 2013, 07:54:15 AM »
yeah still using stock carb for now..and now im also thinking a leak think i may know where its coming so ill check it out
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
superscoot
Re: damn idle
« Reply #5 on: January 29, 2013, 06:57:07 PM »
FIXED!!! no air leak, played with the a/f screw some more hangs just a little for a split second...waiting on a bigger pilot
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
Superstu
Re: damn idle
« Reply #6 on: January 29, 2013, 08:37:19 PM »
On super 9 which way riches up the a/f screw? I've seen a few condescending post.
I just want to know from a kymco owner.
stu
superscoot
Re: damn idle
« Reply #7 on: January 29, 2013, 10:55:35 PM »
turn it in richens it up and turn it out leans in out..remember to turn it 1/4 at a time :)
RIGHT WAY :) thats on the stock carb
« Last Edit: February 13, 2013, 05:25:06 PM by superscoot »
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
Re: damn idle
« Reply #8 on: January 30, 2013, 11:22:22 PM »
..on the oem carb, turning the screw on the left clockwise, makes the fuel mix lean...
..rule of thumb, is that if the fuel mix screw is before the throttle adjusting screw, in the air-flow, then it adjusts air..opening will increase air...
..if the fuel mix screw is after the throttle, in the air-flow direction...then the screw adjusts fuel entry into the mix, so opening will increase fuel...
« Last Edit: January 30, 2013, 11:29:21 PM by wordslinger »
thebatman
Re: damn idle
« Reply #9 on: February 04, 2013, 01:01:10 PM »
before?   pose to be a FUEl screw, not air
"THE BAT"MAN...
Says:
Peters
  • In Glock I Trust
Re: damn idle
« Reply #10 on: February 05, 2013, 03:56:20 AM »
Check this out
http://www.ducatimeccanica.com/dellorto_guide/dellorto_3_4.html
*2001 ZX-50 beater
superscoot
Re: damn idle
« Reply #11 on: February 09, 2013, 11:51:24 PM »
loads of diffrent information flying about it says here on the manaul turn the air screw (a/f) clockwise to richen the mixture or counter clockwise to lean the mixture like wtf so many different posts
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
Peters
  • In Glock I Trust
Re: damn idle
« Reply #12 on: February 10, 2013, 12:34:20 AM »
Your right... Why would we try to help somebody. What the hell is wrong with us.  ::)
*2001 ZX-50 beater
superscoot
Re: damn idle
« Reply #13 on: February 20, 2013, 05:14:29 PM »
lefty lean righty rich that dont go for all carbs tho
04 kymco super 9 ac
70cc malossi bbk
stock cdi
naraku 90 main jet
naraku 40 idle jet
naraku clutch bell
Naraku Variator
malossi c/f reeds
malossi kevlar belt
leo vince exhaust
TheAmishSasquatch
Re: damn idle
« Reply #14 on: November 13, 2014, 06:45:06 PM »
Revival time. I need some help.
