Author Topic: HELP I BROKE DOWN!!!  (Read 2642 times)
xciting250-pigglet09
« on: January 29, 2013, 04:17:22 AM »
Hello fellow friends... i was riding to work one morning... and suddenly i felt a little jolt(kinda when you get off the throttle fast) i lost power, and my oil light came on.... i safely pulled over to the shoulder. got off my "piglet" i didnt see any smoke or oil/fluids coming out... (also no boom noise). i shut it off.... then i try to turn it on again but this time it would not turn and the oil light stayed on.. i ended up calling the tow truck... any ideas on what should i start looking at??? i havent had time to check it yet.. also check my oil and levels are fine.... my 1st inclination was that i blowed up the engine.... any guesses>??
jprestonian
    • a scooter called wanda
Re: HELP I BROKE DOWN!!!
« Reply #1 on: January 30, 2013, 12:02:03 AM »
Could be a number of thangs, but from my experience with a 2007 Kymco People 250, I will guess:
1.) Blown head gasket. Check compression, look for leaks (if the gasket blew to the exterior, and the leaks can be quite small... check under it after it sits for a couple of days).
2.) Broken cam chain, which usually won't cause the oil light to come on, but will kill the engine deader 'n 4:00. Will also probably involve replacement of valves and other top-end goodies.
ce
« Reply #2 on: January 30, 2013, 10:09:12 PM »
Check battery terminals, coil wire and spark plug wire, fuses, kill switch by throttle and side stand, wire connections to throttle body or carb, relay to starter, and examine all apparent wire connections.
The oil light stays on until the engine starts, so if it's not turning over it's likely electrical. Take out the seat bucket and check it all out.
Albuquerque, New Mexico
MaryK
« Reply #3 on: January 30, 2013, 10:50:18 PM »
CE is right, it sounds like the engine died, which is probably an electrical problem, not a major engine problem.
keep us posted,
New Rider in 2010
2009 GrandVista 250
« Reply #4 on: January 31, 2013, 03:08:15 AM »
good news well kinda.... i took the bucket seat off and check the engine everything look normal, then just had the crazy idea and took the cover for the belt and boom... the belt broke/shredded and it got the variator stuck in place thats y engine doent turn on.... so now i just need get new belt and clean all the gunk off.... also since im going to be in the area im thinking of getting new rollers... any suggestions on the size?? i want a higher highway speed/lower rpm
« Reply #5 on: January 31, 2013, 03:16:02 AM »
So that's what happens when the belt breaks....I'll keep that in mind otherwise I might end up rebuilding the engine..Lol!    How many miles did your belt last?
« Reply #6 on: January 31, 2013, 03:19:43 AM »
was the original belt. it had about 9400 miles
ce
« Reply #7 on: January 31, 2013, 05:05:38 AM »
The stock rollers are 23x18 20 gram, so if you can find some 22 gram rollers, mix 3 20s and 3 22s to see if it performs well, then try all 22s.
I tried some 18 gram sliders for a quicker acceleration, but the RPMs were too high and the top end was flat, so I stayed with the stock 20 gram rollers.
The variator nut is tough to get off, make sure your impact wrench is at least 250 ft lbs capable, and hold the variator with a spanner or strap wrench.
« Reply #8 on: January 31, 2013, 05:11:00 AM »
Wow! I have 12,700 on my odo and with the original belt. I think I need to change it now...
« Reply #9 on: January 31, 2013, 05:19:31 AM »
i do commute 4 a week about 56bothways... almost everyday so i do put lots of miles
