Author Topic: dr. pulley sliders or rollers  (Read 1227 times)
« on: January 31, 2013, 06:37:51 PM »
   what side should the rollers face left or right ,. and when you install them , face them right , and install them at 12 oclock  or 6 oclock,. I cant tell from watching the vidios,. seems different people do it one or the other,.   thank for any info,.
streido
Re: dr. pulley sliders or rollers
« Reply #1 on: February 03, 2013, 01:19:01 PM »
Not 100% sure what you mean there but if the rollers have one end that has more plastic on it covering the brass inside then that goes to the left hand side when looking in to the back of the variator( ie variator sitting face down on the floor).
Some rollers dont have a thicker end so these can go in anyway round. If you look at the sides of the ramps you can normally see soke wear on one side where the rollers rub more due to the centrifugal force as they move up and down the ramp.
Hope that helps a bit.
Chaos is my co-pilot.
MotoRandy123
  • Lets Ride!
« Reply #2 on: February 03, 2013, 05:49:14 PM »
Here's a picture, (the side with more plastic covering the core is facing you);
mrmike
  • Syuracuse, NY
« Reply #3 on: February 04, 2013, 12:51:36 AM »
        It gets confusing but he means the roller that is in the 12 o'clock position looking down on the variator. Then put the remaining ones in the same way
