Author Topic: short shaft vs long shaft  (Read 651 times)
« on: February 03, 2013, 07:30:44 PM »
I was given a ok motor off a gy6 50 its a long shaft almost like the agilty 50 the tires are 120/70 12
they are in real nice shape well they work on the agilty my back tire on the agilty is a 130 /70  12
and also well most of the other parts off the motor work for spare parts like the stator and the crank If it ever comes to wear I need theam. just wana save any parts I can.
Re: short shaft vs long shaft
« Reply #1 on: February 04, 2013, 02:09:29 AM »
..a lot of the parts will work. on the a50...
..you could run that tire on the front of your scoot!!!
« Reply #2 on: February 05, 2013, 11:34:56 PM »
Ok here is a pic of the tires can the disk brakes be taken off so you can just use the drum brakes.for the back tire............
