Author Topic: Can not turn key enough to start??  (Read 1239 times)
Bob Brinkley
« on: February 07, 2013, 07:59:55 PM »
I started my B&W 250 yesterday-- ran fine. I let it set and later tried again only to find that the key will turn, but not enough to start??
big blue
Re: Can not turn key enough to start??
« Reply #1 on: February 07, 2013, 09:35:32 PM »
Hello Bob, I had this same issue with a car ignitiion switch. It turned out I just needed a replacement. When the switch goes to the cranking position it just does not make contact so the starter does not energize. Does the starter spin and not start the engine or is there no reaction at all?   Len
Bob Brinkley
« Reply #2 on: February 07, 2013, 11:16:57 PM »
No, it is as though the switch locks at igniton only-- it will not turn enough to start. This seems to be a physical stop before it moves enough to start. I hope I don't have to replace it.
« Reply #3 on: February 08, 2013, 01:57:16 AM »
Try some spray cleaner and lubricant...It might just be accumulated dirt...
big blue
« Reply #4 on: February 08, 2013, 05:38:57 PM »
Vivo may be correct. It could just be a bit of grit not allowing the lock tumbler in the switch to reach start position.
TroutBum
  • 2012 Like 200i (sold)
« Reply #5 on: February 09, 2013, 02:48:26 AM »
I would use compressed followed by some graphite.
