Did you miss your
activation email
Technical | How To
Daelim S5 belt ... please
Topic: Daelim S5 belt ... please (Read 1427 times)
Mroz
Newbie
February 21, 2013, 01:31:04 PM »
good morning everybody!!! my question is kind off topic but i dont know where should i go with this
SO ive got daelim s5 working pretty good but my belt just broke
so i have used cobra's belt but broke right away
...PLEASE IF SOMEBODY KNOW WHAT BELT I SHOULD USE .... i dont have the old one so i cant check the dimension's
please let me know thx
MotoRandy123
Lets Ride!
Re: Daelim S5 belt ... please
February 21, 2013, 01:43:29 PM »
Well a quick search turned up this file on derestricting your scoot, in it it shows an upgraded
belt for your bike "MRP stocks Polini belt number P248.011 which is made for the E-Five
and S-Five. Minimum Cost and Maximum results."
http://www.martinracingdealer.com/REPAIR%20MANUALS/DAELIM/DAELIM%20MRP%20UPGRADE%20STEP%20BY%20STEP.pdf
Mroz
Newbie
February 21, 2013, 08:55:43 PM »
thank you
Mroz
Newbie
Reply #3 on:
March 04, 2013, 01:19:33 PM »
hey guys , so iam back ...
so i bought the polini belt , i change it yeaterday but now the engine wont turn over it only making weird sound ( like hitting metal with metal ) i allready checked the pinion and thats fine ... any idea?
thx martin
Reply #4 on:
March 05, 2013, 02:05:28 AM »
Maybe something else broke when the belt broke....
MotoRandy123
Lets Ride!
Reply #5 on:
March 05, 2013, 01:04:36 PM »
Maybe the belt cover is installed wrong? Some have the kick start gear tied into it and
need to be engaged properly when reassembling? Try removing the cover then try to start
or remove the belt and rotate the rear wheel to see if it is free then rotate the front pulley
to see where thew problem is....
Mroz
Newbie
Reply #6 on:
March 05, 2013, 01:37:27 PM »
problem solved !! when i was changing belt i was spraying the cover and i get rid off the old gasket ... so when i tight the bolt without gasket the pinion was kind of stuck in the bushing and doesnt have enough room to rotate ... oops
) anyway thanks for reply ...
Back
