Did you miss your
activation email
Technical | How To
Odd question about headlights
Topic: Odd question about headlights (Read 994 times)
houndguy
Fear the mangy mutt!
Sr. Member
Your idiotism amuses me.
March 14, 2013, 12:28:25 AM »
Yesterday, I was driving to work and I noticed my low beam headlight was out (it was the reflection in a car I was behind). I switched to high beams and that worked. I drove the rest of the way in on high.
On the way home from work it was dark and with no other cars on the road I thought I would see if the low beams worked. They did.
This morning I go to work, checking the low beams and they are not working. After about 20 minutes of high beams I pull behind a truck and look at my reflection. I switch to low beams and surprise! They worked.
I checked them during lunch and guess what...no low beams.
So loose wire? Or something in the bulb itself?
I was thinking of just switching out the bulb and getting a headlight modulation unit but am unsure if that would work with the 08 Xciting model.
Just another scooter blog -
http://www.2smallerwheels.blogspot.com
West Tennessee, USA
Re: Odd question about headlights
March 14, 2013, 12:48:04 AM »
Sometimes the filaments can break and the light goes out. Then road vibes will "bounce" the broken ends together and "Presto!" they work for a short while only to go out again real soon. Bite the bullet and replace the bulb which I will bet you were gonna do anyway!
March 14, 2013, 01:46:06 AM »
Happened to me.... poor contact inside the switch.... my solution was to play with the switch..hi,low,hi,low or low, pass, low, pass .... after about a week... all was normal... or if you can spray contact cleaner, that will work too...
TauEffect
Scootin a Guilty 50
Newbie
Reply #3 on:
March 21, 2013, 08:33:40 PM »
I have the same issue on my agility 50...its the headlight switch...i use high mainly anyway for added visibility...think I'll try some deoxit
Scootin...please leave a message after the beep
Back
