Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
were do I find a 3mm. spanner
Topic: were do I find a 3mm. spanner (Read 1820 times)
2011 300i downtown 82,265 KM.
March 20, 2013, 03:28:22 AM »
I have been to prices auto , canadian tire, and some auto supply places, no luck so far, has any one done a valve adjustment on there downtown, what did you use to hold valve adjust screw and tighten lock nut,.
MotoRandy123
Lets Ride!
Re: were do I find a 3mm. spanner
March 20, 2013, 02:11:28 PM »
I've heard of people taking a square drive drywall screw and bending it to use as a holder.
They also make special tools with the square bit inside a 10mm socket...
They have a special spanner on this page (called valve adjustment wrench);
http://www.procycle.us/bikepages/dr650.html#ASM-VALVE-DRIVER
Or here's a tappet wrench;
http://www.gearhead.com/09917-14910.html#/s/SUZ//09917-14910/1
Last Edit: March 20, 2013, 02:21:55 PM by MotoRandy123
West Tennessee, USA
March 22, 2013, 07:06:41 PM »
3" adjustable wrench works, too. There is a technique of turning the tiny square with your fingertips and then cinching the locknut. Generally, the square will only turn a tiny bit as you start cinching with the locknut so you have to start with the feeler gage kinda loose so it finishes right on the money with just a bit of drag. It is all trial and error with what ever ya use.
Reply #3 on:
March 22, 2013, 09:30:22 PM »
found a easy 3 mm. spanner ,. an old #2 robinson screw driver that has a tip installed just pullout the tip and you have a # 3 mm. spanner,.
West Tennessee, USA
Reply #4 on:
March 24, 2013, 12:07:08 AM »
What De-dee said.....
Back
