Author Topic: WOLO horn install on downtown  (Read 1373 times)
« on: March 20, 2013, 03:45:23 AM »
   I pick up a wolo horn at harbor freight,it warmed up enough to install the horn the other day  before this snow storm that is ongoing, I removed the front clip to see what I could do,. ended up it bolted in no trouble ,.  on the same bar as original,. just below it is a good spot to bolt it on, removed the hang down bar from original spot and used the bar to off set horn and it fits perfectly,.   it seems to be twice as loud,. I used the same wiring off the old horn just plug it on,. I have a over sized battery, so other scoots may have to run a wire from the battery,. to get enough power to the horn,.
Re: WOLO horn install on downtown
« Reply #1 on: March 22, 2013, 07:09:22 PM »
Is this Wolo about the same thing as the Stebel that sounds like an airhorn on a truck? How much at HF?
« Reply #2 on: March 22, 2013, 09:09:53 PM »
   yes it is a air horn ,. 39.95 at harbor freight I picked mine up in watertown NY.    Bad place to go too, the van is not big enough to pack every thing you want,. and lack of money of coarse,.
