Author Topic: NEW GUY  (Read 1766 times)
TauEffect
  • Scootin a Guilty 50
NEW GUY
« on: March 21, 2013, 04:17:03 AM »
So i just joined...figured I'd say hi and post up some info on my scoot
Gotta 09 kymco agility 50 with almost 13k miles on it...here's a list of some of the stuff I've done:
-no limit DC CDI
-4g koso sliders
-2k torque spring
-2k clutch springs
-hot high energy coil
-iridium plug
-removed stock air filter and intake snorkel, put a pod filter where the intake snorkel attached to the airbox...didn't wanna go with a filter directly on the carb since i ride about 120-150 miles a week for work on this scoot
« Last Edit: March 23, 2013, 02:09:54 AM by TauEffect »
Scootin...please leave a message after the beep
TauEffect
Re: NEW GUY
« Reply #1 on: March 21, 2013, 04:43:45 AM »
You can see in the previous picture how my marker lights used to look, broken and hanging from the wires...i bought the scoot that way...below is a pic of how it looks now.
i removed the old broken lights and trashed em...the rear lights were shorter and pristine, only problem with the rear lights was where the rear light brackets attached to the body, the body plastic was cracked...i put red LED pods where the rear lights were which covered the cracks in the body plastic and reversed the front brackets by removing the alignment tabs...this allowed the shorter lights from the rear to tuck in closer on the front
I also put amber LED marker lights on the handlebar housing...partially for increased visability but also once i get a blinker module for LED lights i will be eliminating the stock lights as blinkers and wiring them along with the gauge lights so they function as running lights...or i might just remove them all together, not sure.
Before and after pics to follow.
« Last Edit: March 21, 2013, 04:59:45 AM by TauEffect »
TauEffect
Re: NEW GUY
« Reply #2 on: March 21, 2013, 04:46:09 AM »
Cracked body panel
TauEffect
Re: NEW GUY
« Reply #3 on: March 21, 2013, 04:47:15 AM »
New LED installed
TauEffect
Re: NEW GUY
« Reply #4 on: March 21, 2013, 04:48:19 AM »
Left side
TauEffect
Re: NEW GUY
« Reply #5 on: March 21, 2013, 04:49:02 AM »
Rear view
TauEffect
Re: NEW GUY
« Reply #6 on: March 21, 2013, 04:51:02 AM »
Front before
Re: NEW GUY
« Reply #7 on: March 23, 2013, 01:26:46 AM »
Nice job. Whats your top speed.
