Author Topic: electric choke disabled  (Read 1489 times)
jerry
« on: March 23, 2013, 08:17:31 AM »
My 2010 agility 125 (1200m) was not running well.  The acceration was not smooth.  It would bog slightly between 15-20mph.  After doing most of the checking of common things, mixture screw, spark plug,dr sliders 13gr,carb. cleaning, etc.  I turned my focus on the auto choke. Found a video on this, showing how to isolate this demond.  Removed the choke assbly. made a gasket to cover the 3 o-rings then put the unit back in  place.  Now for the test: Temp in Fl 66 degrees, It started, but need some goosing, then it ran at idle as it should.  Took it out for a test ride and to my surprise, the accelleration was awsome and the stumble that I had tried to fix was gone.  the throtte was smooth at all stages of acceleration and steady.
tortoise
Re: electric choke disabled
« Reply #1 on: March 23, 2013, 05:51:48 PM »
Yet in a global context, the enrichers on CV carbs seem to be working relatively well.  If you do eventually find that the enriched mixture is beneficial during the coldest Florida months, consider installing an enricher switch.
MotoRandy123
  • Lets Ride!
« Reply #2 on: March 23, 2013, 07:14:33 PM »
Hmm, I wonder why the EPA allows a setup that can waste gas like that?
