Author Topic: Battery recommendations?  (Read 2627 times)
farsed
« on: March 25, 2013, 01:13:16 AM »
How do I find out how good/bad my battery is in...feels like it runs out of charge very quickly (after ~1 week days of not using it)
Also, any recommendations for batteries for the super 8 150?
Re: Battery recommendations?
« Reply #1 on: March 25, 2013, 01:28:25 AM »
Get the biggest and with the highest amp that will fit your compartment...
farsed
« Reply #2 on: March 25, 2013, 01:40:31 AM »
Thanks! I should mention I am noob when it comes to Voltage and Amps, so I don't know what the biggest and highest amp the super 8 150 can take/use?
« Reply #3 on: March 25, 2013, 04:59:45 AM »
The stock is 7ah, I changed mine to 9ah... similar dimensions except for the height.  I don't know if dimensions differ with different brands.
DoubleSC
« Reply #4 on: March 25, 2013, 05:06:57 AM »
You may want to take a look at the larger capacity YTZ10S (or TTZ10S) which has very slight dimension differences.  I got one from a seller on Amazon. It fit fine, and was much cheaper than the orignal YTX7A-BS as well.
DSC
farsed
« Reply #5 on: March 25, 2013, 06:49:29 PM »
DSC
Thanks! there are different brands for YTZ10S (Yuasa $120 or TMS $25)....which one did you get then?
DoubleSC
« Reply #6 on: March 26, 2013, 04:53:31 AM »
Got the cheaper TMS one from here:
http://www.amazon.com/gp/product/B004IUKTKY/ref=ox_ya_os_product
It's worked well since I'd bought it last fall, and the most time it's gone without running/charging so far has been 3 weeks (from which the scooter started right up on return).
DSC
« Last Edit: March 26, 2013, 10:47:53 AM by DoubleSC »
MotoRandy123
  • Lets Ride!
« Reply #7 on: March 26, 2013, 09:32:43 AM »
Just for info the number in the name is the amp hour.
IE YTZ10S = 10 amp hour.
You have to make sure a bigger one will fit. A place like this
http://www.batterystuff.com/batteries/motorcycle/
shows the sizes. AGM is better than standard lead acid too. This refers to the physical construction
of the internals. AGM has fiberGlass Mat that the acid soaks into...
« Last Edit: March 26, 2013, 09:35:19 AM by MotoRandy123 »
farsed
« Reply #8 on: March 26, 2013, 10:58:20 PM »
Thanks DoubleSC!
The suggested one by DoubleSC seems to fit fine as a)he is using it in his super 8 and b)measurements check out fine against the space in my scooter.
