Author Topic: just bought ncy variater for agility 50  (Read 1396 times)
amccraw0
« on: July 12, 2009, 02:21:29 AM »
need the demensions for the roller weights so i can buy some. are they 16x12 or are they 16 x 13  thanks.
Re: just bought ncy variater for agility 50
« Reply #1 on: July 12, 2009, 02:32:24 AM »
...dunnooo about the the ncy, but my Malossi variator has 16X13....
amccraw0
« Reply #2 on: July 13, 2009, 03:43:05 AM »
yeah they are 16x 3 and i bought 8gram rollers is this a good set  up i weigh 165
« Reply #3 on: July 13, 2009, 10:36:21 AM »
...mine came with 9 gr...and that was way too much...initial take-off was ok, however between 25 and 40 mph, accelleration was very slow...and climbing even slight inclines brought me down to 30 mph...I removed three of the rollers, and wow!...what a difference....my engine revs higher than ever, accelleration all the up to 40 is awesome, I top out at 50+ down some good size hills...and climbing those same hills I rarely drop below 38...The Malossi variator also came with a longer main clutch spring...I'm still studying the effects of what that different spring causes...
amccraw0
« Reply #4 on: July 14, 2009, 01:04:07 AM »
i ride on mostly flat roads and im pretty lite will this work with the 9 gr
« Reply #5 on: July 14, 2009, 01:18:39 AM »
...well..it gives me a total of 27 grams...1/4 ounce..lol...
..I weigh about 230 lbs...soaking wet...
..from what I've learned here..I would suspect you need something less than that..
..say around 21 or 24....
..And I'm not sure if a three roller combo, or a 6 roller combo would work better....
..there are more factors at work here...have you ever adjusted your valves?
« Last Edit: July 14, 2009, 01:20:17 AM by wordslinger »
« Reply #6 on: July 15, 2009, 03:50:04 AM »
the problem w/ removing weights is you are making the remaining weights do all the work, meaning faster wear. put in lighter weights to get the same effect, unless you like to tinker w/ them alot.
« Reply #7 on: July 15, 2009, 12:16:44 PM »
..yeah, zombie..I can see how that would be...My dealer was on vacation all last week...Just got in touch with them yesterday, and they're sending me a set of 5.5 gram rollers...
amccraw0
roller weights and slider weights
« Reply #8 on: July 16, 2009, 05:43:58 PM »
whats the difrence between slider weights and roller weights? do u need both
« Reply #9 on: July 17, 2009, 04:17:10 AM »
different names for different applications (same purpose, and effect)
