Author Topic: Mystery Part  (Read 1512 times)
az_slynch
  • Tucson, AZ
Mystery Part
« on: April 01, 2013, 10:48:54 PM »
Took my '12 Yager in for it's 3K service this weekend. Took a hair under five and a half months of in-town commuting to get there and it's been a pleasant ride so far.
I had two side items for the dealer to look into. One, the front brake pads like to drag; often I'll have to manually flip the brake lever forward in order to pull the pads off the rotor enough to keep them from scraping the rotor. Two, I asked that they reinstall the rear outer mudguard correctly. I'd loaned the bike to the shop around the 1800 mile mark so that they could use it to troubleshoot a light blue '10 Yager with ignition issues. Got my oil changed for free, but I noted some sloppy reassembly on my bike: the mudguard wasn't installed correctly and two of the five bolts that hold the rear rack on were stripped.
I figure I should mention that I own a bunch of scooters and work on all of them except the Yager. I figured that if I had a new bike with a warranty, I'd leave it to the professionals to handle the maintenance. Seemed like a good idea in order to avoid warranty issues and to foster a good relationship with my local shop.
When I got the scoot back, I was disappointed to find that they still hadn't installed the mudguard correctly. I grabbed my tools and removed it. While removing it, I noticed a three-prong connector hanging out of the bodywork, just below the battery box. When I removed the mudguard, a rubber diaphragm fell out. I removed the panel below the battery box and behind the mudguard to figure out where the diaphragm/plug came from, and I fould what looks like an evap cannister jammed in the frame. No hoses were connected to either of the two hose connections I could see on the cannister and it was not affixed to the frame, but appears physically jammed between the frame members located between the taillamp and battery box.
Any idea what this thing is? I did not see this part in any of the manual pictures. Page 2-11, mid-page, for the Rear Combination Light Under Cover is the most specific image of the area I'm describing. I'll take a photo tonight after work if possible. Maybe the bike was meant for Cali and this is part of an emission system?
I still have no idea on that electrical plug either. I'll get a pic of that too. I'd like to fix what's installed and not dig too deep into the bike. At this stage, I'm expecting to find more half-baked work. Lesson learned, do not let the shop use your new bike as a troubleshooting tool!  :-\
« Last Edit: April 02, 2013, 02:38:03 PM by az_slynch »
'01 Super Fever ZX 50
'05 Bet 'n Win 250
'10 Yager GT200i
'12 Yager GT200i
'16 K-Pipe 125
'18 Spade 150 stolen April 2020
MotoRandy123
  • Lets Ride!
Re: Mystery Part
« Reply #1 on: April 01, 2013, 11:10:03 PM »
Here's a picture of the canister on my bike, it is connected to a couple of hoses;
That connector is the factory diagnostic connection...
« Last Edit: April 01, 2013, 11:12:14 PM by MotoRandy123 »
az_slynch
  • Tucson, AZ
Re: Mystery Part
« Reply #2 on: April 02, 2013, 12:54:29 AM »
Randy,
     Thanks for the prompt reply! Yes, those are the two items I'm talking about. I guess they just missed putting the diagnostic plug back in the battery box. It looked a bit dirty, but little worse for wear from dangling in the breeze for the last two months.
     I'd need to pull bodywork to check the top end, but I think that cap in your pic that the rightmost hose plugs into has come apart (hence the loose diaphragm in the bodywork). Does the lower end of that cannister (end obscured by the frame) have any hoses going to it, or does it just have a big and little fitting poking out?
« Last Edit: April 02, 2013, 12:57:13 AM by az_slynch »
'05 Bet 'n Win 250
'10 Yager GT200i
'12 Yager GT200i
'16 K-Pipe 125
MotoRandy123
  • Lets Ride!
Re: Mystery Part
« Reply #3 on: April 02, 2013, 09:43:05 AM »
Just two hoses on the top. I was surprised to see it in there too as it's not in the service manual...
Re: Mystery Part
« Reply #4 on: April 02, 2013, 01:46:47 PM »
   what does the other end of the hoses plug into, ???intake ,, exhaust,, gas tank,,,???
MotoRandy123
  • Lets Ride!
Re: Mystery Part
« Reply #5 on: April 02, 2013, 09:05:46 PM »
I think one goes to the fuel filler funnel (it's around the filler hole for overflow) and the other goes to
the intake past the airfilter to burn the fumes when you start the bike. It shouldn't be a problem
because of where it's located. On some bikes it's easy to flood it with liquid gas and cause rich
running problems...
Re: Mystery Part
« Reply #6 on: April 03, 2013, 03:15:45 AM »
  thank you for showing me what it looks like,. now I can find it on my scooter,.  300i D T
