Author Topic: Drain Hose From Under Bike  (Read 942 times)
PassedByAScooter
« on: April 04, 2013, 02:06:55 PM »
You probably know what I'm talking about. The clear tube that has a crimp attached to it, so that you can drain it if need be. A couple rides back,  I drained it and it was pretty gross. This was the first time. I haven't had to do it since. What exactly is this for? Is it bad if there's brown stuff draining?
Thanks in advance!
PBAS
2010 Kymco Yager
2009 Kymco Agility 125
Re: Drain Hose From Under Bike
« Reply #1 on: April 04, 2013, 03:57:02 PM »
It drains the crud from crankcase ventilation joining at the forward end of the airbox, atmospheric side. NOT draining this tube will cause misfire and hesitation. At least the Owner's Manual tells you it is there and to drain it "periodically" but not what it is for. I missed it too!
PassedByAScooter
« Reply #2 on: April 04, 2013, 04:35:27 PM »
Thanks CROSSBOLT! In somewhat relieved to know that it is probably normal!
PBAS
2010 Kymco Yager
MaryK
« Reply #3 on: April 04, 2013, 06:17:36 PM »
It collects more crud in cold and wet weather.  which reminds me, we need to get DH to drain mine.
scoot safely,
New Rider in 2010
2009 GrandVista 250
