Author Topic: Video on a variator  (Read 1976 times)
RURC
Video on a variator
« on: April 04, 2013, 09:55:43 PM »
I was trolling You Tube and came across this. I thought that this is something that others might be interested in. I know that it is not a Kymco but the process is the same.
Oldscoot
Re: Video on a variator
« Reply #1 on: April 04, 2013, 11:15:53 PM »
Very cool - thanks.  Once again - a picture is worth a thousand words.
sissy mary
« Reply #2 on: April 05, 2013, 09:30:16 AM »
At you tube type in variator kymco xciting 500 & u will find a video out of Germany where he installs Dr Pulley weights. It shows the complete variator change. Very good. :-*
RURC
« Reply #3 on: April 09, 2013, 04:14:52 PM »
The problem is that it is not in English, or at least the one I saw was not.
sissy mary
« Reply #4 on: April 10, 2013, 11:32:07 PM »
The one I view has no speach. Just music as he takes it apart and puts it back together again. The title has Dr pulley rollen or something like that in the title. :-*
sissy mary
« Reply #5 on: April 12, 2013, 08:39:33 AM »
When on youtube, type in (Dr Pulley Rollen und Slider einbau Kymco Xciting 500 i R ABS). The video was put on by MegaXciting 500. No speach, none needed. If you have electric impact wrench u can change belt , variator, clutch yourself. Very easy. Make sure washer that go's on first behing variator is beveled side up against the engine case. the belt is directional, look for arrows on new belt, and when you place the back/inside pulley half (the pulley half that holds the roller weights) on a table in front of you, the rollers go into slots open side to the left, closed end plastic side to right, just like he does in video. NO GREASE ANYWHERE. NO LOCKTIGHT LIKE SOME IDIOT TOLD ME TO DO. So easy even a Sissy Mary can do it. :-*
LoveMyKymco
« Reply #6 on: April 12, 2013, 02:19:54 PM »
LoveMyKymco
« Reply #7 on: April 12, 2013, 02:20:32 PM »
Heres one of my CVTs.
