Author Topic: electrical fault  (Read 1012 times)
down but not out
electrical fault
« on: April 08, 2013, 07:56:16 PM »
Have a 51 plate vivio. Electrics have gone tits up battery draining when trying electric start, indicators also fubar any ideas on cause and solution ???
naughty lee
  • 64 mph and pushing
Re: electrical fault
« Reply #1 on: April 08, 2013, 08:20:40 PM »
If the battery is knocking on a bit (age) or the scoot has been sat around for ages, the battery I'd probably flat. Put it on charge overnight
down but not out
« Reply #2 on: April 08, 2013, 09:33:36 PM »
Battery is fine holdin charge as used regularly to get to work fuse tested also
jawolf
  • you are only old when you forget how to play!
« Reply #3 on: April 17, 2013, 07:18:25 PM »
I had some of the same issues on a people s 200. I found that the battery had a week cell and it still showed 12.5 volts, just not enough amps. Also check for ground faults between battery, starter, and frame. I used a pair of jumper cables to bypass each area and found the problem. also check starter wiring for faults. All i did for this was to go through every connecter and pulled and repluged after using dielectric grease. also a good idea for all electric connections.
