Author Topic: Top Case Rattle when bike idles.  (Read 1730 times)
complex
« on: April 10, 2013, 11:15:25 AM »
My GT300i TOP Case hinge rattles when the bike is idling.  This is caused by free play in the hinge pin.  Is anyone else having the same issue?  Remedied?  I tried using Hot Glue to make the hinge pin assembly tighter but this only lasted for a few days.
2012 Kymco 300i
2012 Kymco Super 8 50T
2010 Honda Sh150i
1999 HD Fatboy/Heritage
leomagnus
  • Providence, RI
Re: Top Case Rattle when bike idles.
« Reply #1 on: April 10, 2013, 03:12:59 PM »
I had the same issue but my lock came loose..so I used Gorilla glue on it about 3 times..letting it dry and reapplying...and i have not had a problim with it since. It will still rattle a little bit. You could always throw a little something in the case and put some weight in it to lessen the rattle.
« Last Edit: April 10, 2013, 03:14:55 PM by leomagnus »
Rome, Italy
'97 Honda SH50
'98 Aprilia SR50
'01 Gilera Runner 180
'05 Honda SH150
Warwick, RI, USA
'12 Kymco People GTi 300
'18 Kymco Xciting 400i ABS
'22 Kymco AK550 ABS
« Reply #2 on: April 10, 2013, 07:49:59 PM »
   check under the case I lost one of the rubber bumpers and it rattled real loud,. givi 55 box
complex
« Reply #3 on: April 10, 2013, 10:51:40 PM »
The rattle is comming from the pin hinge in the factory case.   It's a quality control issue and poor manufacture.   I could try asking Kymco to warranty it.   Thats why I wanted to know if other had seen the same with their factory boxes.
2012 Kymco 300i
2010 Honda Sh150i
mrmike
  • Syuracuse, NY
« Reply #4 on: April 11, 2013, 12:32:40 AM »
I just replaced the factory topcase on my GTI300 with a Shad SH40cargo. I wanted to access the case without the key sometimes. I can also take the case right off if I want.
« Reply #5 on: April 11, 2013, 08:52:54 AM »
Try spraying liquid lithium grease in the hinge.  It comes out liquid then solidifies afterwards...
or wedge a piece of small rubber on the back cover near the hinges so the lid will be pushed a little bit upwards when closed,.. tightening the hinge pins.
