Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
front turn signals
Topic: front turn signals (Read 1213 times)
mnpugdog
Sr. Member
front turn signals
April 11, 2013, 02:01:42 PM »
Question for those with US spec DT. Is there a working bulb in the front turn signals and just the wiring needs to be reconnected or do I need to order bulbs. And if I have to order bulbs are they the same size as the rear turn signals?
As a side does anyone know what the fitment is for the liscense bulb? I want to replace that with a LED too.
jwalz1
Jr. Member
Re: front turn signals
April 11, 2013, 02:56:22 PM »
This has been covered before when someone was modifying their bike. If I read this thread correctly (on page 3):
http://www.kymcoforum.com/index.php?topic=4244.30
They are dummy bulbs. Not sure if you just need to install other bulbs or if they must also be wired into the system. If you look down about a dozen threads you will find a pdf format Downtown manual that should be of help.
Last Edit: April 11, 2013, 03:03:33 PM by jwalz1
West Tennessee, USA
April 11, 2013, 07:00:43 PM »
The wiring diagram I have for the 300i shows those bulbs as "Position Lights" left and right for Italian models. US models apparently have "dummy bulbs" and may have the wiring behind them. Would look snazzy as blinkers!
mrmike
Syuracuse, NY
Reply #3 on:
April 11, 2013, 10:03:59 PM »
I just did this to my 2012 People GTI300 last weekend. I just wired the exsisting sockets to the lower position lights. The wiring and sockets were there, but I had to buy the bulbs. I don't know if they are the same as the DT300.
Blue '23 People S 150i ABS Moto Discovery GPS bar, Shad SH33 top case, Iridium spark plug, Black reflective graphics, Battery Tender ring terminal cable, LED tag light.
2011 300i downtown 82,265 KM.
Reply #4 on:
April 12, 2013, 07:17:55 PM »
I have a 2011 model DT. the lights are there , but both wires were grounded together,. I rewired to running lights,. if I think of it I will order LED lights for them,. it would be brighter ,.
Back
