Author Topic: Kymco Mongoose 250 (kxr) start problem  (Read 4431 times)
melenroom
« on: April 15, 2013, 12:12:42 PM »
Hello,
I own own an Kymco Kxr 250 atv in the Netherlands that is the same as the Mongoose 250.
I have a start problem.
Normaly the Atv dont't start, but when i start en the same time putiing the gear to the front he will run.
I have a you tube movie uploaded that you can see the problem.
KymcoRacer
Re: Kymco Mongoose 250 (kxr) start problem
« Reply #1 on: April 19, 2013, 12:57:56 PM »
Well, I am not to familiar with that model but I would bet that the nuetral safety switch is not adjusted correctly. I would look for a switch somewhere along the shift linkage. The switch could be located by the transmission. It will probably be some sort of switch with 2 wires. It's purpose is to prevent starting in gear but allow it to start in nuetral. Just the opposite of what yours is doing. Hope this helps.
2012 MXU 500 IRS
2013 Mongoose 90
