Author Topic: Adding heated seat and hand grips  (Read 1429 times)
soldout
« on: April 18, 2013, 06:24:09 AM »
I want to add heated seat and hand grips to my Agility 125.
My question is can the stock electrical system handle the additional load from heated seat and hand grips?
What if I change some of my lighting to LED bulbs will that help?
Thanks!
This is the seat specs.
Application
Carbon fiber can be trimmed to fit
Specification
Power Supply: DC 12V
Current: 5A
Measure: 40cm x 21cm (8"x15.5")
Weight: 0.7Kg
Temperature:
Range: 30°C-75°C
Indicator light RED= ON
Specs for the heated hand grips just say 10/24watts.
« Last Edit: April 18, 2013, 06:31:37 AM by soldout »
12' Burgman 400 - Throttle Lock, Best Back Rest, Passenger Backrest, Ram Ball Mount
09' Agility 125 - Puig Touring Windscreen, Shad 29 , 12V Underseat, Taplights, Ram Ball Mount, City Grips
09' Metropolitan - 12v, Ram Ball Mount
Re: Adding heated seat and hand grips
« Reply #1 on: April 18, 2013, 06:42:02 AM »
That is a good question... most heated seats have two heated areas..driver and passenger...and each consumes about 30 watts, so that's 60 watts if the controller is set to maximum... Heated grips also draws about the same, 30 watts...   Our headlight is around 35 watts, tail/brake lights around 20 watts.   The concern here is the amount of reserve power of your electrical system/stator, which I don't know...  ;D    and yes, changing some lights to LEDs will help...
« Last Edit: April 18, 2013, 06:44:18 AM by Vivo »
soldout
« Reply #2 on: April 18, 2013, 07:31:57 AM »
Amps 5 x Volts 12 = Watts 60 ...So yes the seat draws 60 watts and the hand grips 24 for a total of 84 watts.
Ok, so lets say I change out all my turn signals, tail and brake light.  How much power could I free up from the system?
Oh and I always ride with my HIGHBEAM on!  Does that make any difference from 35watts running on highbeam, like 40watts?
« Reply #3 on: April 18, 2013, 07:53:08 AM »
LED turn signals are insignificant because they're not always on.
Tail lights only around 8 watts and goes to around 20 when you hit the brakes.  So a LED tail light will be around 2 watts when it's always on and up to around 5 when you hit the brakes...
I would say it would be very far from your needed 84 watts...
BTW you also need to know the power output of your stator...
soldout
« Reply #4 on: April 19, 2013, 04:27:11 AM »
Ok, so measure the power output of the stator.  In the repair manual it shows how to test the AC generator charging system.  Could i measure the voltage coming off there with the engine running?
« Reply #5 on: April 19, 2013, 05:14:43 AM »
If one can measure the actual output wattage of the stator, you can have an idea on its capacity and reserve capacity...
soldout
« Reply #6 on: April 19, 2013, 05:21:18 AM »
Ok, so I need to figure out how to measure the wattage coming off the stator.  Then I will upgrade most of the lighting to LED.  Would adding a 2nd battery help the system?  I wonder where I could hide 1 since I dont want to lose and under seat storage.
« Reply #7 on: April 19, 2013, 07:29:34 AM »
   take a look at sheep skin wool for a seat cover, O watts,.
« Reply #8 on: April 19, 2013, 07:40:36 AM »
and rechargeable battery powered heated gloves...
MotoRandy123
  • Lets Ride!
« Reply #9 on: April 19, 2013, 09:55:01 AM »
You can use the 8 amp computer led controller to reduce the draw on the heated things.
It has a fet that switches on and off and allow you to set a temperature you like. I did
that on my BMW...
You take ot out of the box and mount it somewhere;
http://www.ebay.com/itm/PWM-Dimming-Controller-For-LED-Lights-or-Ribbon-3528-5050-12-Volt-8-Amp-DIMMER-/140636548137?pt=US_Car_Lighting&hash=item20be976c29
You'll probably use 50% of max power that way.
