Author Topic: Air horn on my Like  (Read 1146 times)
91cavgt
Air horn on my Like
« on: April 25, 2013, 09:00:43 PM »
A couple of days ago I installed an air horn on my Like since the stock horn is VERY anemic!
Here is what the stock horn sounds like;
http://s8.photobucket.com/user/91CavGT/media/KymcoLike200i007_zps622468a7.mp4.html
Here is what the air horn sounds like;
http://s8.photobucket.com/user/91CavGT/media/KymcoLike200i019_zpsea2ae992.mp4.html
All told I have about $20 tops invested in this and I think it is a VERY good upgrade.  I passed a couple of dogs on the side of the road today, so I honked the air horns at them and they immediately jumped and looked in my direction.  There's no way that would have happened with the stock horn!
2012 Like 200i  in black
Urbestfriend
Re: Air horn on my Like
« Reply #1 on: April 26, 2013, 03:06:04 PM »
Is this a Nautilus or WOLO Horn?  And where did you mount it.  All my Bikes (4) and both cars and truck have had these horns.
91cavgt
« Reply #2 on: April 26, 2013, 06:29:59 PM »
Neither, it is a cheap $15 air horn setup from Harbor Freight.  Add in the wiring and fuse holder and you can put it together for less than $20.
If you go to the Like 200i sub forum you will see a whole right up on this with pictures showing where I mounted the horns and compressor.
Urbestfriend
« Reply #3 on: April 27, 2013, 12:01:28 AM »
Thanks... A nice installation,  one I hadn't thought of.  I've mounted my WOLO's  $37.00 at Harbor Freight
directly to a hole drilled in the lower part of the windshield.  Any air horn is a safe and commanding item.
You may likely find you scare a lot of people and make a few mad.  I'm very impatient when lights turn
Green and if they don't move they usually get woke up.
