Author Topic: [SOLVED] agilty 125, wont start.. could be battery? ignition coil? cdi? stator?  (Read 11896 times)
yjb
and i do believe it is a DC cdi, which is what i ordered and will try out tonight
yjb
ok i tried it out, and it didn't start (but i may have possibly had the kill switch in the wrong position.. doh!) and it blew a fuse while i was trying to start it with the new cdi and hooked up to my buddy's truck to jump it..
bad news.. i changed the fuses out (the two by the battery) and i still have no power at all.. no brake lights, no horn, no fuel gauge, nothing.....
doesn't anyone know if im missing a fuse somewhere to check?
anyone have any thoughts about earlier things i've posted?
Aceforever
I think I had similar problem to your one mate. Instead, there was an issue with the left-handle-brakes and the electric starter would not work. So I took my scooter in to the workshop and got them to look at the problem why the electric starter wasn't turning over. They told me the fuse and the left handle brakes caused the problem because the brakes was jammed. So now its running good expect the I can't the left hand brakes anymore so I the electric starter works with the right-handle brakes.
My guess, it could the fuse or the one of the handle brakes.
Good luck my friend ;)
yjb
hey folks!
so after fussing and fighting with it, basically dissembling it down to bare bones, all plastic panels came off.
All wires were inspected. All connectors were checked. Everything was run with a multimeter.
I just couldn't figure it out.
Finally I took it to the shop, Sparks in Tucson Arizona, they just called me, after 2 weeks of waiting,
and the expert answer is...
Pulser coil!!!! it's a part that works with the stator that generates ac power that goes to the rectifier and to your lights and whatnot.. ( i think?)
Wish I would have investigated a little more.. If I would have just looked up actual definitions and descriptions of what parts do what, I think I could have figured it out. I really wish I would have read what I've put below for info about pulser coils and ignition systems in basic motorcycles.
They also told me the carb is clogged up because it's been not running for over a month.. and it needs to be cleaned..
all in total, less than $200 at the shop, and should get it back running today!
I'll update later on how it all comes back together...
too bad i missed most of the spring on the scoot, and now its 105+ every day..
so it goes :)
Pulser Coil & Ignition Systems
The Pulser Coil is the heart of your engines timing & ignition system. This section has information on how the components and system work & troubleshooting tips.
The Pulser Coil, (often called Pickup Coil, or Timing Coil) is responsible for providing the timing signal to the ignition control box on modern motorcycles with solid-state ignition systems. The majority of motorcycles from the late 1970's and up use this system for reliable, accurate, and low maintenance ignition control. On previous models, points-controlled systems were used, and while cheap and simple, they required routine maintenance and component replacement to ensure reliability.
Points & Mechanical Advance Ignition Systems
On most motorcycles up until the late 1970's, timing and spark control was done with a set of cam-driven points, which were mechanically advanced or retarded to control timing. The points would make contact, allowing current to build up. When the points were opened, and contact broken, the current was discharged through a coil to step up the output to high voltage in order to produce an ideal spark across the spark plug. This system was very simple, and similar to the system used on automobiles. The common replacement parts are the points, which wear down from constant friction as they open and close, and the condenser, which is a small capacitor to prevent arcing and premature wear & failure of the points. Timing is handled via a mechanical advance system. The timing of the points openening is advanced before Top-Dead-Center of the engine at higher RPM's, usually by means of a spinning weight.
CDI (Capacitor Discharge Ignition) & Solid State Ignition Systems
Modern ignition systems use a solid state (semiconductor) controller to handle the ignition spark timing. The control box, often called a CDI box, or black box, handles multiple functions. The internal electronics are either powered from the battery (DC ignition systems, most street motorcycles), or in AC directly from the stator (most dirt/offroad motorcycles). Current from either the stator or the battery is used to charge up an internal capacitor. This capacitor is then discharged through the ignition coil via the spark plug to generate the very high voltage necessary for a good spark. The CDI box has digitally stored timing maps, to handle advance of the ignition depending on RPM, and sometimes other variables, such as a throttle position sensor (often called TPS, a sensor which varies it's resistance based on the opening of the throttle). The CDI box is fed timing data from the Pulser Coil, which produces a short duration, low current, high voltage pulse in relation to the Top Dead Center (TDC) piston location in the engine. This is explained more in depth below.
The Pulser Coil and Flywheel Timing System
The pulser coil is a very simple component. It is generally housed in a small plastic container, and internally potted with epoxy or some other oil resistant material. The pulser coil itself is made up of a small magnet (the exposed metal you can see on the front of the housing), which is wound with a coil of very fine wire. The pulser coil may have one or two wires exiting the case to connect to the ignition box. On one wire systems, on side of the internal coil is grounded to chassis ground through the mounting hardware. On two wire systems, a wire from each side of the coil exits the case to connect to the ignition box.
The pulser coil generates it's timing pulse with help from the flywheel (Refer to the illustration above). The outside diameter of the flywheel has at least one timing mark, which consists of a raised ridge, spanning some percentage of the outer edge of the flywheel. This ridge is pronounced, and has sharp leading and trailing edges. The Pulser Coil is mounted to the engine sidecase in very close proximity (some thousands of an inch) to the flywheel, spaced to be extremely close to the timing ridge(s). The timing ridge is referenced to the Top-Dead-Center (TDC) piston location inside the engine. As the timing ridge on the flywheel spins past the pulser coil, the timing signal is generated. The leading and trailing edges of the raised metal ridge produce a low current, high voltage pulse, either positive then negative polarity, or negative then positive, depending on the direction of the coil winding inside the pulser coil. The ignition box then uses this signal to reference the piston location, and given it's inputs (RPM and TPS) it will determine the correct time to fire the spark plug, by discharging the internal capacitor out to the ignition coil, and finally the spark plug.
General Pulser Coil Troubleshooting Steps
The Pulser Coil, as a unit, is not usually serviceable. It is a sealed component, and should be replaced if determined to be a problem. Pulser Coil problems sometimes manifest themselves in hard starting situations, but usually failures result in no spark at all. When the pulser coil fails it will usually produce no output pulse, or a very weak one. This is hard to verify, without special tools such as an oscilloscope to view the pulse. The usual failure is similar to a stator failure mode, the wire coil inside fail with the insulation breaks down and a short occurring, or the wire breaks inside causing an open circuit. The wiring external to the pulser coil assembly can be damaged as well, causing a connection issue. The only real troubleshooting method is to check the resistance of the Pulser Coil wires, to ensure they match known specifications, making it likely the coil inside is intact.
1: Lookup Pulser Coil technical specifications for coil resistance. These are available from the bike's service or owners manual, or our website's product page for our coils.
2: Obtain a Digital MultiMeter (DMM). Set to the hundreds resistance range if the meter is not auto-ranging.
3: Attach each meter lead to one wire from the pulser coil. If there is only one wire exiting the pulser coil, attach one meter lead the wire, and one to the metal mounting foot of the pulser coil housing.
4: Verify resistance reading matches the known specification. For most Pulser Coils this in the range of 180ohms-300ohms, but please compare to exact specifications for your part.
5: If either an short is detected (no resistance), or an open (OL - overload, on most meters), the coil is definitely bad.
6: There are no serviceable parts in a pulser coil, short of repairing a damaged section of the wiring harness. Please replace with a new coil.
that was some reading...
claynine
Pretty uncommon for the stator coils to crap out.  Very easy to overlook.  Apparently it works fine when it got warm but sporadic when cold.  Hope you get your scoot back real soon.
bold2000
What was the problem I have the same issue.
pulser coil - diagnosed by his scooter shop.
bold2000
Thank you, do you know where I can find the main ground connection on the frame?
No. With seat bucket out can you trace the neg batt cable?
To see mine, on a LIKE200i, I have to lay next to right side with a flashlight to see it.
Cyclepedia.com might have a manual which you could purchase for your scooter.
scooterfan
Installing a DIY main ground directly from the battery surely can't hurt. It should be a lot easier installing a DIY ground than trying to find the original ground.
