Author Topic: ...main clutch spring..  (Read 1457 times)
« on: July 13, 2009, 10:26:37 PM »
...i installed a new malossi variator...it came with a longer (by approx. 1.5 inch) clutch spring...anybody have any ideas about the longer spring?...like what would be the benefit?
peace
mookie
Re: ...main clutch spring..
« Reply #1 on: July 13, 2009, 11:16:47 PM »
 ask the seller...
« Reply #2 on: July 13, 2009, 11:39:42 PM »
...good idea..but I got it last Monday..installed the same day...My seller is 140 miles away, and they have not answered their phone all last week..and they're closed on Mondays...
peace
Shaka
« Reply #3 on: July 16, 2009, 03:04:54 PM »
Wordslinger, did you find anything out about the main clutch spring?
« Reply #4 on: July 16, 2009, 04:01:02 PM »
Shaka,  Send Zombie a message on that...He could explain it better than me...lol..
Urbestfriend
« Reply #5 on: July 16, 2009, 05:43:53 PM »
If Urbestfriend could offer a comment on springs.  If the spring they sent fit,  then you should have no major issues.
Compression or Extension Springs are an interesting science.  There's wire diameter, coil spacing, coil
diameter and spring length that are all part of a spring equation.  Urbestfriend is an engineer and periodically
chooses springs for a design he may be working on.   All the pre-mentioned factors all add up to spring rate
(load the spring will support at a certain load or length.  Not sure which way you wanted to go up / down,
but this is likely what's happened.
