Author Topic: Fill to the add hole, or .18 L ?  (Read 1913 times)
« on: April 28, 2013, 11:55:08 PM »
My manual says add .18 L gear oil, while the service manual says to add to the fill hole in the rear end.
Is this the same? (I can't see in there to see if we're talking the same amount of oil)
tclhb
Re: Fill to the add hole, or .18 L ?
« Reply #1 on: April 29, 2013, 01:38:58 AM »
My bottle of oil that I bought was marked in ml. I definitely added more than 180 to get to the fill hole. I noticed after I did the oil and gear oil my scooter launched better off the line.
Tom. Huntington Beach, California
« Reply #2 on: April 29, 2013, 01:39:55 AM »
check your manual for the exact amount, as if you over fill it could over flow into the air intake filter if it is the same as the downtown,. and not in the manual is check the puke tube,. (small tube with a plug in it ) near the air vent intake,.the downtown it hangs off of the variator cover rear end,.
tclhb
« Reply #3 on: April 29, 2013, 01:52:57 AM »
Trans, not motor oil
91cavgt
« Reply #4 on: April 29, 2013, 12:08:21 PM »
I changed the rear end fluid in mine at 200 miles.  I filled it up until it started coming out of the fill hole.
300 miles later at my next engine oil change when I looked at everything really close and I see no fluid leaking anywhere.
2012 Like 200i  in black
TroutBum
  • 2012 Like 200i (sold)
« Reply #5 on: April 29, 2013, 02:50:52 PM »
+1
You can also blow through the seals a time consuming and costly job.
When I replaced the gear oil for the first time I had it drain into a metric mixing cup. It was about 180 ml. This tells me the owners manual was right.
spatechjohn
  • 2013 Like 200i
« Reply #6 on: April 29, 2013, 07:34:26 PM »
The service manual says .18 L
SonicSix
  • 2012 Like 200i
    • My Scooter Site
« Reply #7 on: April 30, 2013, 02:02:34 AM »
My book say 200ml or 200cc for gear oil.  I use a feeding syringe that holds 50cc and squirt the new gear oil in (4 times).  Easy to do and no mess.
2012 Kymco Like 200i Black and Blue
White Bell Revolver EVO Modular Helmet with Dark Smoke Shield
States I have scootered in...
TroutBum
« Reply #8 on: April 30, 2013, 05:39:04 AM »
I read that somewhere, but I think that is when you do an overhaul. For maintenance changes its .18 liters.
« Reply #9 on: April 30, 2013, 06:16:07 AM »
Yes, .18   ;)
