Author Topic: How you check the gear lube?  (Read 2148 times)
Joe7911
« on: April 30, 2013, 11:23:14 PM »
Is there a way to check the level of gear lube on the Kymco DT 300i?
All I can see its measure 8OZ and thats it no way to tell if you are low or not?
Any Ideas?
kayakbuilder
Re: How you check the gear lube?
« Reply #1 on: May 01, 2013, 01:26:04 AM »
With my Zuma, I just changed it at the specified intervals.  The right amount always came out and I replaced it with the proper amount.  Haven't look at when it needs to be changed on the downtown but I am still not ready for my first oil change.
'13 Downtown 300 White
'08 Yamaha Zuma Raven 70cc BBK, LV ZX Exhaust, CF Reeds, Sport Windscreen, SOLD
'99 Yamaha Zuma II 70cc BBK
James 1:27
MotoRandy123
  • Lets Ride!
« Reply #2 on: May 01, 2013, 09:39:55 AM »
Well on your scoot the inspection is to change it;
« Reply #3 on: May 02, 2013, 02:31:32 AM »
Use a bent wire.... and insert in the filler hole to check for lube level....
kneeslider
« Reply #4 on: January 25, 2014, 03:57:17 PM »
How far below the filler hole should the gear oil level be?
2019 Yamaha X-Max 250
« Reply #5 on: January 27, 2014, 01:34:03 AM »
Hole level..
« Reply #6 on: January 27, 2014, 02:30:32 AM »
on the downtown it is below hole level , how much,  I have not seen anything on where the level is , so put in the right amount and put in vivos wire and let us know how low it is, use copper wire and flatten the wire part that go,s in so the oil will be seen on the wire,. # 8 or #10 wire should do the trick
« Reply #7 on: January 27, 2014, 02:59:50 AM »
Plus/minus a few ml of oil is ok... as long as you can see oil on the wire...  ;)
kneeslider
« Reply #8 on: January 27, 2014, 03:44:16 AM »
For me in the past, i just fill to hole level.
But that was smaller 150cc scooters, where the 100ml tube of gear oil was a one shot per service item.
