Author Topic: Idles a bit. Dies when any throttle given  (Read 1860 times)
TheMadProfessor
« on: May 06, 2013, 12:43:09 AM »
The scooter was running great for the longest time and I put a bit of sea foam into the fuel. Recently try to start and it will idle for a few seconds then die. I did get it to idle for a few minutes but at the slightest twist of the throttle it dies.
I have cleaned the carb and exactly the same result.
Any thoughts?
Re: Idles a bit. Dies when any throttle given
« Reply #1 on: May 06, 2013, 02:18:39 AM »
check air and fuel mix...
TheMadProfessor
« Reply #2 on: May 06, 2013, 06:49:52 AM »
Vivo thanks. Do you have some tips on how I do that?
Thanks
« Reply #3 on: May 06, 2013, 07:16:36 AM »
Thanks
I know how, but I won't suggest you experiment with your carb without some minimal experience on tuning/adjusting your carb...   All I can say is that you have air and fuel adjusting screws at your carb's side...
MotoRandy123
  • Lets Ride!
« Reply #4 on: May 06, 2013, 09:50:07 AM »
Sounds like an air leak into the manifold after the carb...
