Did you miss your
activation email
Scooters - 50cc
Proper Micro Bit Set For Jets
Topic: Proper Micro Bit Set For Jets (Read 2342 times)
Kenho21
Sr. Member
I live my life 0.402336 kilometers at a time
May 09, 2013, 02:32:08 PM »
Anyone know where to find a micro drill bit set with ranges between 1mm-1.4mm or thereabouts for drilling out main jets? Preferably in .2mm increments or close to it.
Re: Proper Micro Bit Set For Jets
May 10, 2013, 01:20:23 AM »
I get my drill bits at harborfreight. look in the dept. that sales the dremmel tools. the dremmel drill bits will work also.
Kenho21
Sr. Member
May 10, 2013, 01:26:25 AM »
Will definitely check it out. Thanks brotha! Gearin up for the ridin season...
ScooterCommuter
Full Member
Reply #3 on:
May 12, 2013, 03:15:52 PM »
Also look for gas nozzle reamers for welding torches. Those come in a wide range of precision sizes. Make a small hole with your dremel and then ream it to the precise size you want. More accurate since you will have less error from drill swing.
Back
