Author Topic: 2012 Super 8 2t 50cc US model turn signal light  (Read 1071 times)
Andyca714
« on: May 10, 2013, 08:36:46 PM »
Can someone please tell me what number of the turn signal bulb cause I'd to change it to led . I'll appreciate it
« Last Edit: May 10, 2013, 08:53:23 PM by Andyca714 »
Fogie
Re: 2012 Super 8 2t 50cc US model turn signal light
« Reply #1 on: May 10, 2013, 09:31:07 PM »
In the case of turn signals, it's a little more complicated than swapping in LED bulbs. LEDs have much lower resistance than conventional ones, and your flasher unit will think they're burned out; this will cause them to flicker at a much higher rate than the normal flash. You need to add compensating resistance into the wiring. There are units for this available from LED bulb distributors.
2012 Kymco Frost (Yager) 200i - Toronto, Canada
Andyca714
« Reply #2 on: May 11, 2013, 12:55:46 AM »
Its 12093 RY10w , is it the same with 1156 bulb ??
« Reply #3 on: May 11, 2013, 02:17:43 AM »
You need to replace your stock flasher to an LED flasher.
Also the 12093 RY10w is NOT the same as 1156.    The base of 12093 uses the type BAU15s and the 1156 uses the BA15s  base....
« Last Edit: May 11, 2013, 02:25:59 AM by Vivo »
Andyca714
« Reply #4 on: May 11, 2013, 02:36:11 AM »
Got it , thank you sir   :)
