hi everybody. i have a kymco zx 50 super fever that i haven't used for almost a year now.
the thing is i didn't do anything to winterize the thing since i live in mn
but today i take it out and i figure why not give it a shot
i turn the key on, battery works because i can use horn/signal/lights.
the problem is though when i press on the ignition, the engine spins a few cycles but then it just flats out and does nothing but buzzzzz until i release the ignition.
i'm not sure as to what it is but i'm guessing, because of how long it's been sitting, that the fuel line/pump could be clogged or carbs are gunked up. the oil light is on and i will be doing an oil change but i doubt not having enough/clean oil could cause it to NOT start, right?
any help would be appreciated thanks
