Did you miss your
activation email
Scooters - 50cc
what's the stock compression ratio
Topic: what's the stock compression ratio (Read 2863 times)
phatboy
Jr. Member
May 14, 2013, 11:37:15 PM »
Hey, can't seem to find this information, all pages say N/A
I want to install a BBK and would prefer keeping it close to stock compression to avoid burning pistons or having to use special high octane gas (best pump gas here is 91).
I see a few different kits available, one appears to have a flat top piston and stock head, says "raises" it to 9:1 compression. Like this one:
http://enviromoto.ecrater.com/p/3369520/ncy-72cc-big-bore-kit-fo
So that means it's lower than 9:1?
Agility 50 w/72cc BBK, A9 cam, stock airbox and exhaust (both drilled out), remove air tube restriction, stock head, stock carb, 105 main jet, CDI cut, smooth variator boss, stock variator w/5g rollers
Re: what's the stock compression ratio
May 15, 2013, 01:51:46 AM »
The Kymco website states the compression ratio of Agility 50 is 11:1
baddi
Sr. Member
Top speed: 38 km/h and fuel economy: 50 km/l
May 30, 2013, 11:19:24 AM »
It is a good idea to have a proper service manual. I recommend this:
http://scootergrisen.dk/scooterhjemmeside/download/kymco_agility_servicemanual.pdf
as it has alot of technical specifications.
Reply #3 on:
June 02, 2013, 01:32:51 PM »
my manual says its 11. The last time I hooked a cage up to it it read 125 on the gauge which I know is realy good I have seen some as high as 130 thats the best you can do. If you go under 110
you are looking at rebuilding you motor.
Back
