Author Topic: CDI Modification  (Read 2124 times)
yz250htj
CDI Modification
« on: May 15, 2013, 03:12:56 PM »
OK to cut CDI or purchase after market Kymco rated performance CDI
Any potential problems through this mod to engine ?
Bray0671
Re: CDI Modification
« Reply #1 on: May 16, 2013, 04:15:48 AM »
Cut CDI just did mine got 5-7 mph out of it!
LewisKA50
« Reply #2 on: May 26, 2013, 09:53:15 AM »
Do you just have to cut it and that's it? Or do you have to change something's?
Cheers.
« Reply #3 on: May 26, 2013, 10:17:43 AM »
You will have to change out the drive boss and a bigger main jet.
LewisKA50
« Reply #4 on: May 26, 2013, 04:53:25 PM »
I see, is that expensive?
Bagel
« Reply #5 on: May 26, 2013, 05:00:14 PM »
I'm new to this jus got me a kymco yesterday an want to derestrict it got a lot of information from here where can I purchase new drive boss an bigger jet from and is there any other restricters on it that need to come off
streido
« Reply #6 on: May 28, 2013, 08:07:46 PM »
Any scooter or decent bike shop should sell them,there are loads online or ask your localkymco dealer for the parts,most stock them. Dont cut the cdi without 1st doing the boss and jet.
Chaos is my co-pilot.
« Reply #7 on: May 28, 2013, 09:22:59 PM »
Mine came with the bike so I was lucky but I also went up to a bigger jet I have a 85 now.
Bagel
« Reply #8 on: May 31, 2013, 08:09:12 PM »
What will it do if i cut the cdi without replacing the jet and boss first
woodcutter
« Reply #9 on: May 31, 2013, 10:13:18 PM »
engine is gonna be in high revs, top speed will probably remain the same, belt wear will increase and mixture could be lean but uphill will be better.
higher revs require more fuel, so, smooth drive boss, 82 jet and then cdi cut. Just my advice  :)
« Reply #10 on: June 01, 2013, 11:12:10 AM »
x2 all 3 must be done. Call the dealer and see if they have theam mine did.
