Did you miss your
activation email
Scooters - 50cc
08 agility 50 auto enricher
Topic: 08 agility 50 auto enricher (Read 2691 times)
scooterman11
Jr. Member
May 17, 2013, 08:03:06 PM »
I know for a fact my auto choke isn't working on my 08 agility 50, I have replaced it many times and they still don't work, how do I test it and I'm sure I have a electrical problem!
tortoise
Re: 08 agility 50 auto enricher
May 17, 2013, 08:25:29 PM »
MotoRandy123
Lets Ride!
May 17, 2013, 08:26:17 PM »
Here's the schematic, maybe your resistor is bad?
Last Edit: May 17, 2013, 08:29:39 PM by MotoRandy123
scooterman11
Jr. Member
Reply #3 on:
May 17, 2013, 08:40:23 PM »
Is that a part of my wiring harness or is it included with the new auto enricher, because the auto enricher plugs in to my wiring system?
Reply #4 on:
May 17, 2013, 10:57:38 PM »
To buy pass all that. You can put in a gravity flow gas tank. And then you can also take off the emission controil. you can use the same tank but you need to take off the peadcock and replace with a new valve. scoot runns great like that. stops all the guessing with if gas is geting to the carb. I have a gy6 scoot I have been running like that for years eats up more gas but scoot runns great.
MotoRandy123
Lets Ride!
Reply #5 on:
May 17, 2013, 11:02:16 PM »
Well from that drawing it looks like the G/B wire goes to it. Maybe meter that wire to gnd and see if you have 5 ohms?
phatboy
Jr. Member
Reply #6 on:
May 18, 2013, 02:10:40 AM »
i though i remember seeing a manual choke conversion kit, cant remember where but i am thinking about one myself because my choke doesnt like to shut off all the way while riding i need to shut down the engine and restart
Agility 50 w/72cc BBK, A9 cam, stock airbox and exhaust (both drilled out), remove air tube restriction, stock head, stock carb, 105 main jet, CDI cut, smooth variator boss, stock variator w/5g rollers
MotoRandy123
Lets Ride!
Reply #7 on:
May 18, 2013, 11:42:19 AM »
There was a discussion on that a little while ago. See here;
http://www.kymcoforum.com/index.php?topic=8492.msg93647#msg93647
Reply #8 on:
May 18, 2013, 09:56:36 PM »
Nice Ill have to check in to that............
scooterman11
Jr. Member
Reply #9 on:
June 13, 2013, 07:27:17 PM »
Hey guys where is this resistor, Is it farther down by the battery
Back
