Author Topic: To Derestrict or not to derestrict  (Read 1558 times)
Squeekie0809
« on: May 19, 2013, 07:32:00 PM »
From what I understand changing the CID unit can give a big improvement on speed but my local garage says it makes the engine more problematic revving higher, what are your experiences?
MotoRandy123
  • Lets Ride!
Re: To Derestrict or not to derestrict
« Reply #1 on: May 19, 2013, 08:34:25 PM »
Well Kymco used to give the dealers instructions on how to derestrict. The bike was designed to
rev higher just was restricted for the states that said 30 MPH for 50cc. If you get an aftermarket
CDI with no redline you might be able to hurt the motor by overreving...
Squeekie0809
« Reply #2 on: May 20, 2013, 11:21:13 AM »
Oh so if I get an unrestricted cdi to keep up with traffic (35mph at the most) it should be fine, at the minute seem to be doing 28 mph with frustrated cars behind me.
MotoRandy123
  • Lets Ride!
« Reply #3 on: May 20, 2013, 08:29:57 PM »
What I said was that if you derestrict your stock CDI you should be fine.
An aftermarket one might allow overrev and valve float.
« Reply #4 on: May 21, 2013, 02:58:07 AM »
MotorRandy is right on!   here's another explanation...
If your engine was designed to rev for 10,000 rpm and the factory restricted it to run for only 8,000 rpm.... you can derestrict it to get the optimum 10,000 rpm, and still not ruin your engine.
However, if your engine was designed for 10,000 rpm and you installed a CDI with no limiter which can over-rev your engine to 12,000 or 14,000 rpm, then, you will ruin your engine...
hope this helps....
naughty lee
  • 64 mph and pushing
« Reply #5 on: May 21, 2013, 07:40:29 AM »
Swapping out the stock CdI will not give you an instant speed fix. Having had a zx50 apart over a hundred times, I can tell you that for free.
Follow my guide, it will take you a day, and your scoot WILL reach 50mph+ without spending more than £15 or ($25) I would buy a max of three sets of rollers 4.5g 5.5g and 7g to experiment with
fuertesport
« Reply #6 on: June 12, 2013, 09:27:21 PM »
help where   is the guide
simon
