Author Topic: top box rattle fix  (Read 3640 times)
boo
top box rattle fix
« on: May 22, 2013, 03:20:20 PM »
For those that might be interested, here is a simple and inexpensive fix for the oem top box rattle on the GT.
First, stuff some foam rubber between the bottom of the box and mounting bracket.
Then cut some one inch pieces of black electrical tape. Place tape on edge of box in the area where white lines are in picture. It may take 5-8 pieces per area. Add tape as needed to stop rattle.
This takes the slop out of the hinge pins.
I did this to mine and now it is quiet and shakes less.
Sorry for the funky picture.
« Last Edit: May 22, 2013, 03:23:12 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
kidbuffalo
Re: top box rattle fix
« Reply #1 on: May 23, 2013, 12:53:07 AM »
Hey Boo, Here's a permanent fix that I did. That tape well get sticky in the heat. Pull the pins out and find something like a straw ( I used a piece of shrink tubing ) that well slide onto the pin. Put a little silicone grease on the pin so it can slide in the tubing. I then put a little gorilla glue on the tubing and push it into the hinge part of the top. While the top is off. Let it harden overnight and pull the pin out, trim off the excess tubing and now there's no slop in the hinge. Hope I explained it well enough .
boo
« Reply #2 on: May 23, 2013, 02:00:45 PM »
Sounds good kidbuffalo.
More than one way to skin a cat.
I haven`t had any problems with my fix but, if I do later I will try your fix.
Thanks.
300GTI black
« Reply #3 on: May 24, 2013, 03:11:48 AM »
How about pulling the pin out.... using a vise, bend the pin just a little bit, just enough for the pin to be tight in the hinge....
KentonLynne
« Reply #4 on: June 20, 2013, 05:00:19 AM »
I had this annoying problem of the top box rattle when I first got my 300gti last spring.  I immediately bought a roll of closed cell 1/8" foam tape (about $2.00) and cut off enough to go around the entire box and just just stuffed it into the lower channel.   It took all of 3 minutes to do, has stayed in place over a year and not only stopped the rattle but seems to make the box leak-proof as well.
allen1371
« Reply #5 on: June 22, 2013, 01:08:55 PM »
Here's the fix.......Remove the box.
MassScoot
« Reply #6 on: July 11, 2013, 01:29:52 PM »
Here's a better fix...Buy a Shad SH40 Cargo top case like me. The supplied Kymco top case is fair @ best, It does the job, but it's pretty cheap overall IMHO.
« Last Edit: July 12, 2013, 04:02:50 PM by MassScoot »
Gloucester, MA. (Home of the Perfect Storm)
2012 Silver Kymco GT300i (Biondi Windshield/Shad SH40 Cargo Topcase)
2015 White Honda PCX150 (Shad SH37 Topcase)
2013 Yellow Lance PCH125 (Shad SH33 Topcase)
« Reply #7 on: July 12, 2013, 03:39:44 AM »
Yeah! who needs a box?
MassScoot
« Reply #8 on: July 12, 2013, 04:02:33 PM »
Vivo: That's INSANE! I guess people in the Philippines get the most out of their scooters!
boo
completely happy with OEM box
« Reply #9 on: July 13, 2013, 07:43:55 PM »
A little tape and wa la.
300GTI black
