Author Topic: Scooter sat all winter. Stalls and sputters  (Read 1690 times)
jen
« on: May 27, 2013, 06:58:16 PM »
Ok, my wife's kymco agility 50 (2013, with only 100 miles on it) sat all winter, and had no fuel stabilizer in it. (I thought she put some in, of the stuff that I bought.) We started it up today, and it will start, sputter, and finally get up to speed, but then if you take it for a ride, it sputters and stalls at stops signs, and you have to restart. The gas tank is full right now.
I'm assuming siphon the gas off as a starter.. and then what? Run the engine to get the rest out? Do we need to clean carb/fuel lines/fuel filter/anything else? (Links to docs on how to do this?)
It's under warranty and we could have the dealer take a look, but we'd have to get it picked up, and that's like going to be $100+ due to the distance to the dealer.
Any help is appreciated.
Re: Scooter sat all winter. Stalls and sputters
« Reply #1 on: May 27, 2013, 09:11:55 PM »
Frist just drane most the gas and the maybe add a little seafoam to like 1/4 gal of gas and run the scoot tell its gone to see if that help clean things up. you will only need like 1 oz of seafoam.
if that dont work ya a good cleaning of the carb and gas lines will do it. you can do a search on this form to show you anything you need to know. even youtub can help.
« Reply #2 on: May 28, 2013, 02:18:42 AM »
Small engines do that after storage... usual cause is a gummed or clogged idle jet... Do what blue suggested to clear those clogged lines...
jen
« Reply #3 on: May 28, 2013, 09:39:00 PM »
Ok hopefully will try sometime this week and report back.
Thanks!
MotoRandy123
  • Lets Ride!
« Reply #4 on: May 28, 2013, 10:06:15 PM »
That's why I love my fuel injection!
« Reply #5 on: May 29, 2013, 12:08:49 AM »
I love gravty flow.....takes out the guessing games if fuel is geting to the carb or not.
« Reply #6 on: May 29, 2013, 01:25:29 AM »
Fuel injection is not exempted from gum and varnish...  ;)  Better than carb tho... but once it fails, you don't drain your tank, you drain your wallet...
