Author Topic: Is there a way to reset ECU after new plug?  (Read 1693 times)
« on: June 03, 2013, 05:10:28 PM »
Is there a way to reset the EFI (ECU) brain after a new (iridium) plug is installed? Now my idle is faster - which equals less engine braking as I stop. I want to go back to previous idle.
Any ideas ?
Disconnect battery ?
Turn key off and on without a start?
Ideas?
Re: Is there a way to reset ECU after new plug?
« Reply #1 on: June 04, 2013, 03:13:21 AM »
Any ideas ?
Ideas?
If scoot's ECU is same as car...then Yes.... then ride the way you ride for the ECU to "re-learn"...
keith217
« Reply #2 on: June 04, 2013, 04:10:40 PM »
You can disconnect the battery for a couple minutes and normally that'll completely reset the ECU.
« Reply #3 on: June 04, 2013, 10:39:55 PM »
x2
