Author Topic: Torque settings  (Read 699 times)
Gizmo327
  • Venox 250
Torque settings
« on: June 03, 2013, 06:29:27 PM »
I have a Venox 250 and the starter clutch had to be fixed,  I have the torque settings for the one bolt that holds the clutch in place on the spline.
But what i am looking for is the setting for the three bolts that hold the clutch pack together. I have parts ordered and on the way. found the instructions on removing and checking clearance but not hot on taking it apart and back together.
What happened those three bolts that hold the pack together loosened off and jammed against the reduction sprocket and kept the starter engaged :(
thanks in advance for any help
MotoRandy123
  • Lets Ride!
Re: Torque settings
« Reply #1 on: June 03, 2013, 08:19:34 PM »
Well you can find the manual here;
[url]http://www.manualedereparatie.info/en/download/kymco-venox-250-Service-manual.html[url]
It should have what you need....
OOPS it's in Italian! Maybe you can get it translated?
« Last Edit: June 03, 2013, 08:22:21 PM by MotoRandy123 »
Gizmo327
  • Venox 250
Re: Torque settings
« Reply #2 on: June 04, 2013, 07:42:51 AM »
thanks, i finally found it
